lrghustletrees63 Posted January 17, 2016 Report Posted January 17, 2016 Looking for 26mm or 28mm pwks with intake boots for banshee. Watever ones i find a better price for first. Sent from my LGL15G using Tapatalk Quote
lrghustletrees63 Posted January 17, 2016 Author Report Posted January 17, 2016 Looking for 26mm or 28mm pwks with intake boots for banshee. Watever ones i find a better price for first. Sent from my LGL15G using Tapatalk Do i have to do alot of ajusting to get the 26 or 28s to run good on rz 350 motor, i just want more bottom end grunt for wood rideing. I allready have banshee reeds in it if that helps. But everything ealse is stock. Sent from my LGL15G using Tapatalk Quote
Shee_fast Posted January 17, 2016 Report Posted January 17, 2016 You can bore your stock carbs to 28s... Sent from my VS810PP using Tapatalk Quote
lrghustletrees63 Posted January 17, 2016 Author Report Posted January 17, 2016 (edited) You can bore your stock carbs to 28s... Sent from my VS810PP using Tapatalk The carbs that are on my rz motor now are bigger then then that. I dont have stock banshee carbs. I was seeing if stock 26mm carbs or 28mm carbs help with lowend to mid range power Sent from my LGL15G using Tapatalk Edited January 17, 2016 by lrghustletrees63 Quote
mywhiteshee Posted January 19, 2016 Report Posted January 19, 2016 Stock carbs with cables and tors Sent from my SM-N910P using Tapatalk Quote
mywhiteshee Posted January 19, 2016 Report Posted January 19, 2016 Also have intakes Sent from my SM-N910P using Tapatalk Quote
