Intakes ?
Can i just get a pair of intake boots for a 40mm set of carbs and put just the boots on a set of 35mm intakes? I just dont know if the opening in the intake itself would still flow correctly since they are setup for 35-38mm carbs. Im not against buying new intakes but its a hell of alot cheaper to just buy the 40mm boots. Thanks!!
Sent from my SM-N910P using Tapatalk
Got a rotary tool? Ultimately it depends on the manifold and if the 40mm boot will sit on it properly. If you have that, then open it up inside by hand.
It would be a helluva lot easier to just buy what you need though.
Edited by trickedcarbine
