tfaith08 Posted January 17, 2016 Report Share Posted January 17, 2016 I spoke with Cam at Redline and I'm sending my engine out around the first of Feb. I need to figure out what pipes to run.Engine will be a 421 race gas serval ported for MX, 33mm PWKs, VF4s. Cam recommended CPI over Shearers for this build, but also said that I may want to research other pipes depending on what I want as far as power delivery. Any recommendations? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted January 17, 2016 Report Share Posted January 17, 2016 If he says cpi... Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted January 17, 2016 Author Report Share Posted January 17, 2016 If he says cpi... said that I may want to research other pipes depending on what I want as far as power delivery. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 17, 2016 Report Share Posted January 17, 2016 Snipers will likely make more peak HP/TQ and have a better curve than CPI or Shearer. We tested them at Redline on some Cubs and a Serval. Snipers were better on all motors. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted January 17, 2016 Report Share Posted January 17, 2016 Snipers Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted January 17, 2016 Report Share Posted January 17, 2016 See if anyone has a set of SLP and snipers to send to sweet home so he can dyno them all with your engine. That should clear any doubts. I think if sniper would of did big bore in frames, ida tried a set for my serval. Then again, it's not like ill be able to use nearly all the power it makes as is. I think there was a dyno sesssion where all these pipes were tested back to back in the dyno section. edit* founds this in a quick search http://bansheehq.com/forums/index.php?/topic/158181-421-serval-pipe-test/ Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 17, 2016 Report Share Posted January 17, 2016 SLP won't pull as long as Snipers. They won't make the same peak power. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 17, 2016 Report Share Posted January 17, 2016 I'd bet they would huck that motor right to 9K like a freight train, but it would feel like it's hitting a wall once it got there. Not much over rev on those SLP's. But with your Carb choice, that may be ok for what you want. Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted January 17, 2016 Author Report Share Posted January 17, 2016 I'm more concerned with a wide powerband. I want it to pull down low (hence serval and race gas) as well as up high. If I knew I could rev the SLPs up to about 10.5, I'd run them. I may bite the bullet and try them, but I don't want to blow through too much money. I'd like to have some SLPs but I've never seen any used for sale. If I buy some to try, I'd lose out on at least $150 if I decided to sell them. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 17, 2016 Report Share Posted January 17, 2016 SNIPERS FFS, no one listens to anything. Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted January 17, 2016 Author Report Share Posted January 17, 2016 I'd buy some if I could find someone to buy the SLPs for $100 less than what I paid if I decided to sell them after cam tested them. That information would be worth $100 for me. Hell, I'll have $4500 in everything by the time I'm done, what's $4600 to make sure I'm getting the most out of it? Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted January 17, 2016 Author Report Share Posted January 17, 2016 SNIPERS FFS, no one listens to anything. I'm listening, it's just that the link shows snipers making the same curve as shearers, only 5-15hp less throughout. Unless there's something significantly different since 2012, I don't think I follow. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted January 17, 2016 Report Share Posted January 17, 2016 Why do you need pipes to pull from lets say 6.5-10.5 rather than 5.5-9.5? why the magic 10,500rpm ceiling? Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted January 17, 2016 Author Report Share Posted January 17, 2016 There's more wiggle room with more rpm. If I'm off the right side of the bike and need it to keep pulling for another second or 2, that rpm difference may not allow me to keep accelerating. I'd rather have a flatter curve than anything. Idc what makes that happen. Extra rpm is just a little nice at times. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
chuck81673 Posted January 17, 2016 Report Share Posted January 17, 2016 I have used Shearers and presently run Snipers on a 4mil ported Serval. I've never had it on the dyno, but in my opinion the Snipers pull harder out of the bottom and up the curve. On top both pipes feel about the same. I have had many other people ride my quad and all of them agree that the Snipers do pull harder. Again this is only my opinion and I don't have any hard data to back this up, but I don't regret spending the extra money to buy the Snipers, it was worth it. Quote Link to comment Share on other sites More sharing options...
