No power to lights
My lights were not working so I thought I had a bad stator so I replaced it installed new one and I have no voltage to my lights still.
Wires from stator on the bike right now(new stator)
Yellow to Black from stator I have 0.2-0.3
White/red to white/green I have 117
Green to Red I have 13.9-14.4
Not sure what else to check made sure all grounds are good and even check to make sure the flywheel is grounding good.
Any would be great thanks
My brake light bulb is good my fronts I have disconnected since they broke when I crashed a while ago.  But I have no voltage going to any of lights.  Is there a way to test the voltage regulator
 Use a DMM and check the voltage from the regulator
