nrakovec Posted January 11, 2016 Report Share Posted January 11, 2016 My banshee has the old style V-force reed valves (i think they are the original or 2's, still has carbon fiber petals) and this weekend at the dunes, one of the petals completely broke off. The engine still ran at mid-low rpms so I got it back to camp. I'm ordering new reeds, but I'm wondering if I should do I top end on it since the petal went through the engine? I was first going to do a compression check and was thinking of taking the intake/exhaust pipes off and pull the plug to take a look at the bore, pistons, and rings to see if they are damaged or scratched up. I did some searching and couldn't really find any info on this. Is it common if the reed breaks for it to just go straight through the cylinder, sit in the cylinder for a bit and cause damage, sit in the crank case or a bit of all of that? Any one have any experience with this? Thanks! Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 12, 2016 Report Share Posted January 12, 2016 Total tear down. Doing the top end won't show you if the bottom end is ok. Quote Link to comment Share on other sites More sharing options...
possum Posted January 12, 2016 Report Share Posted January 12, 2016 Ive had it happen. I made sure no screws were missing on the reeds and replaced pedals and ran it for another season. Tore it down later that year to find nothing. Quote Link to comment Share on other sites More sharing options...
Keno Posted January 12, 2016 Report Share Posted January 12, 2016 Might as well tear it down if you have time. But as possum alluded to, the carbon reeds usually don't do any damage and pass through. Definitely check to see if any screws are missing. Quote Link to comment Share on other sites More sharing options...
nrakovec Posted January 12, 2016 Author Report Share Posted January 12, 2016 After talking to some people, I think I'm going to pull the head and make sure the top end looks good and there aren't any pieces still in there and that the rings aren't sticking. It seems like one of the big advantages of the carbon fiber petals is that they are designed to not harm the cylinder if they go through. Maybe this summer when I have time, I'll look at the bottom end. Quote Link to comment Share on other sites More sharing options...
Keno Posted January 12, 2016 Report Share Posted January 12, 2016 Sounds good. Let us know what you find. Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
