Trail tech light lenses?
You may just want to get trail tech units if you are looking to buy online.  I usually get them from rockymountainatv.   I have bought MR16 landscaping bulbs at home depot but then you need to solder on leads.  The trail techs come with leads already installed.   If you do buy local, the 10 degree beams are the spot bulbs and the flood bulbs are like 35 degrees or something like that it will be listed on the box.  Also you are looking for a 35 watt bulb unless your stator is upgraded then you can get away with 50 or 75 watts.  Look for the bulbs that say coolwhite not warm white, the warm ones put off a more yellow looking light
Better yet buy the MR16 led bulbs from Home Depot. Their about $15 each but work way better and surprisingly out last any of the halogens.
Should be these:
http://m.homedepot.com/p/Philips-35W-Equivalent-Bright-White-3000K-MR16-Dimmable-LED-Light-Bulb-453498/205449967
