landonschmidt Posted January 9, 2016 Author Report Posted January 9, 2016 i wouldnt be leaning it any more. that temp with open air box, i would have started richer. how does it start ? from cold ? I have 290s coming nxt week.Anyways it started decent like 2nd maby 3rd kick when it 45+ out. Now it takes 5 kicks at bout 25-30 out. Sent from my LGLS990 using Tapatalk Quote
landonschmidt Posted January 9, 2016 Author Report Posted January 9, 2016 My last banshee started first kick no matter the temp. That was back when i was even dumber far as jetting goes, i had 22cc domes, pipes, k&n, light porting, and vitos super stock pistons..with all that i only ever changed the main jet to 290 and left the pilot std. Sent from my LGLS990 using Tapatalk Quote
trickedcarbine Posted January 9, 2016 Report Posted January 9, 2016 Warm your bike up on old plugs and then find a straight away. pull up to the straight away and change to new plugs. The run wfo thru fifth gear when wide open in fifth, pull clutch on and kill it. Coast to a stop, pull plugs and replace with old plugs. Then when back home, cut new plugs to see if the chocolate brown color is a 2-3mm thick ring. Post pics.You mean WFO in 6th gear....... Quote
wayne_smith97 Posted January 9, 2016 Report Posted January 9, 2016 lol wayne hasnt found 6th yet I can never reach the top Quote
willaduncan Posted January 10, 2016 Report Posted January 10, 2016 That plug looks a little dark I'd drop atleast 1 size jet and do a correct plug chop.... You want mocha color the thickness of a dime Sent from my iPhone using Tapatalk Quote
sleeper06 Posted January 10, 2016 Report Posted January 10, 2016 Don't drop anything yet tll u perform test rite way, color is deceiving from normal riding Quote
landonschmidt Posted February 4, 2016 Author Report Posted February 4, 2016 Well climates been rough so havent done a plug chop yet...but.. Im thinking ahead to what i want and, i want to throw on a coolhead and an adjustable timing plate @ +4 degrees. My question is (with my current setup and being at 500-700ft elevation) how small domes can i run and still use pump gas? Thanks Sent from my LGLS990 using Tapatalk Quote
