Hey. Finally got the banshee to run and shift right to be able to do a plug chop. I'm thinking lean on the chop but just want to confirm and to see how many sizes I should go up.
It was a 5th gear pull since I didn't have the room for a 6th gear pull.
Cheetah 72mm bore, 7mm stroke
Pump gas domes by Andy at No Limit
39 PWK with 50 pilot, middle clip, 165 mains
Pods
Cpi inframes
93 octane with Golden Spectro, 40:1
Sea level
~30 degreesebe4af1c9fd590fe7be7d31021c8a553.jpg610d18f311408412b9d7338701837177.jpg6c589a8e56edf9688bbbe2207af6bc19.jpg5bfa2fd760b4b83e722d8d5d6f30c0a0.jpge3e5cb765735ed97e983b6167186ad2d.jpg134ca25ceab76fd44015200ecbc857dc.jpgb7f079ba86dfdce3b402f2f4afac1311.jpg1bddc5c8754e6dac9ccd2f93752b08c3.jpgb9d294217f1615d36e1ae819ba049d47.jpg
Sent from my VS990 using Tapatalk
-Back the timing down a degree. (look at the depositing on the tip of the strap)
-172 on the main
-Maybe a 52 on pilot (how does adjusting the screw affect it)
-Needle I would leave till the main is dialed. Then worry about the transition. One thing at a time.
That's assuming this thing really was making enough load/heat to get a good reading in fifth. If that's the case, you're pretty lucky you didn't get it wound out in 6th.
Ok cool. Thanks for the input. I think as far as the pilot goes I was adjusting the air screw all the way in to a half turn. The idle was still climbing at a half turn out
This is a PV motor. Don't know if that makes a difference in your opinion on the pilot.
Here are some pics of the plugs I put about 20 minutes of ride time on. d452ae89abead9a55494b43d50497e7f.jpg1f9e7f7d3f34143d081b4abb8b8493b1.jpg88a7ec1e73890ffba127475438cc491d.jpga79bc7397c7bfe242f4da316afa94840.jpg16fbfa5256eabb23a4c718209b4d087d.jpg
Could be rich on pilot and needle and lean up top. The first photo with the small edge of metal that's blackish, was that wet? If so it's probably washing the plugs from being rich. Hard to tell with out crisp photos.
The flat of the plug was just a tad oily/wet. I'm thinking about the same with the pilot being fat and the main lean. I tried getting better pics but that was the best I could get.
