dsnellgrove241 Posted January 1, 2016 Report Share Posted January 1, 2016 Hey guys I bought this bike 2 years ago didn't really ride it much but the bike absolutely ran fantastic started up first kick every time I got into an accident was on the track and a guy on a dirt bike lost control and hit me at about 40 -50mph pretty much totaled my quad out put me in the hospital for a while but I rebuilt the whole bike everything ran vantastic same thing still started on first kick then I added some boyesen dual stage power reeds recently and everytime I kick it its leaking out of the overflow tubes and will not start even with the choke in it still floods out I did everything I was supposed to do as far as the reeds make sure the surface was clean everything was laying flat and nice I don't understand what I could have done wrong I'm new to banshees this is my first build Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted January 1, 2016 Report Share Posted January 1, 2016 I'm assuming you mean fuel is leaking out of the overflow on the carbs... Check your float hieght Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted January 1, 2016 Report Share Posted January 1, 2016 Also check the the rubber needle valve..it might be worn out also Sent from my VS810PP using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted January 1, 2016 Report Share Posted January 1, 2016 Or it could be dirty Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
dsnellgrove241 Posted January 1, 2016 Author Report Share Posted January 1, 2016 Thanks for the help I will check all of it Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
camp0429 Posted January 1, 2016 Report Share Posted January 1, 2016 You should do a leakdown test as well, very common for air leaks at the reeds/intakes. Quote Link to comment Share on other sites More sharing options...
dsnellgrove241 Posted January 2, 2016 Author Report Share Posted January 2, 2016 Got it started was a stuck plunger in right carb thank u all ...new issue it is idling perfect but when you go to give it gas it will not rev up kind of bogs down and it backfires every once in a while Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
Shee_fast Posted January 2, 2016 Report Share Posted January 2, 2016 Check your slides make sure they are in correct Sent from my VS810PP using Tapatalk Quote Link to comment Share on other sites More sharing options...
dsnellgrove241 Posted January 3, 2016 Author Report Share Posted January 3, 2016 Thank u all again ....blows my mind the parking brake was causing all the problems Sent from my SM-G928T using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted January 3, 2016 Report Share Posted January 3, 2016 Thank u all again ....blows my mind the parking brake was causing all the problems Sent from my SM-G928T using Tapatalk The parking brake is a great tool until it fails, I've seen people spend HUNDREDS chasing the very same issue Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted January 4, 2016 Report Share Posted January 4, 2016 The parking brake was causing fuel to come out of the overflow? Quote Link to comment Share on other sites More sharing options...
willaduncan Posted January 4, 2016 Report Share Posted January 4, 2016 No he had compounding issues Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
