Oldskool83 Posted December 24, 2015 Report Share Posted December 24, 2015 I bought a pair or proteck ones and they came with a rubber bushing. If was kinda small to I went to lowes and just bought a rubber grommet and used a longer bolt and bolted to the frame. Problem solved. The oem mounts do not last on bikes. Quote Link to comment Share on other sites More sharing options...
Buster91dg Posted December 24, 2015 Author Report Share Posted December 24, 2015 I bought a pair or proteck ones and they came with a rubber bushing. If was kinda small to I went to lowes and just bought a rubber grommet and used a longer bolt and bolted to the frame. Problem solved. The oem mounts do not last on bikes.[/quoteI want something to absorb the vibration I feel like direct metal with rattle do what size grommets did you use Quote Link to comment Share on other sites More sharing options...
Oldskool83 Posted December 24, 2015 Report Share Posted December 24, 2015 They sell all kind of sizes. I used one about .25" thick in which a 8mm bolt fit thru. Ended up being about the same size grommett used on the air box of my 85 200x. Don't over think it too much man. Just go there in person pick a size that works for you and buy it. End of story lol. Quote Link to comment Share on other sites More sharing options...
Sheedawg28 Posted January 11, 2016 Report Share Posted January 11, 2016 I recently bought these. I had cascade solid mounts before. I like the adjustability these offer. They don't come with bolts though so you'd have to supply your own. I mostly ride my bike on an Mx tracks haven't had an issue with them whatsoever. Only thing that sucked was that they don't offer them in the colors they did I would've picked them up in a different color for sure but I'm happy, this design with the rubber in between the middle takes out vibrations but nothing noticeable compared to the solid mounts as I never had issues with those either. Quote Link to comment Share on other sites More sharing options...
