Dome Question
JordyRoo
Domes are about volume. The less volume they have, more compression you will get.
That's the easy part.
Now, what do do you need for your setup, compression wise? pump gaz, race gaz, engine config etc. That's a lot of parameters to deal with.
So, that's why, you will get this answer most of the time: Ask your builder.
You say educate myself, that is why ive made the thread in the 1st place. Its not as simple as picking up the phone here in the UK, there is no specialists for banshees. I wont be doing the porting or the machine work. I will be assembling but i need to know where to start & how to work things out so i can work with my tuner.
Parts over here are also a nightmare to get. My cylinders are in great nick & are already 66mm bore.
Nothing wrong with blaster Pistons if you know what your doing , you need to assemble the motor and measure how far Pistons stick out cylinder . Write that down add.050 and that's the step you need then you need to decide on angle and cc usually when I port someone cylinders I can order domes set up the way I want
