Need help! Clutch problem
Owlbert
So the deal is I installed a new clutch and got everything back together clutch worked good I rode it for a few hours and was headed home and the clutch lever froze and the back wheels locked up so i shifted it in neutral and pushed it home and tore it back down and the inner hub and the pressure plate was all busted up. So my question is does anyone know what would cause that to happen?
Something let go.where is it tore up? The friction surfaces or inside?
Maybe you over tightened the springs and put a hair line crack in the fingers, maybe you left something loose. Did one of the fibers break?
Could be a few things. At this point you need to determine what it possibly was. You can try posting pics.
