Bennett131 Posted December 12, 2015 Report Share Posted December 12, 2015 There, you can see a little better where the case halves come together. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted December 12, 2015 Author Report Share Posted December 12, 2015 There, you can see a little better where the case halves come together. Ahhh I understand now. The line from the joined cases is what it is measured off of. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted December 12, 2015 Report Share Posted December 12, 2015 Yes. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted December 13, 2015 Author Report Share Posted December 13, 2015 What's the stock setting at? 0? Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
camatv Posted December 13, 2015 Report Share Posted December 13, 2015 yes 0 stocker. +4 on most will be ok on pump gas depending on dome design. you can modify the stock plate to go up to 4 nothing wrong with a dyna problems peeps have had were results of running non resistor plugs. the dyna is digital and just like any dirtbike running digital ignition the electrical "noise" from the plug will fuck with it. and yes a rpm limiter is kinda nice. but not the way your thinking. more like in a launch control situation. with the programming capacity you can also run a lot of timing in the lower rpms then take it out as the bike rev's. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted December 13, 2015 Author Report Share Posted December 13, 2015 yes 0 stocker. +4 on most will be ok on pump gas depending on dome design. you can modify the stock plate to go up to 4 nothing wrong with a dyna problems peeps have had were results of running non resistor plugs. the dyna is digital and just like any dirtbike running digital ignition the electrical "noise" from the plug will fuck with it. and yes a rpm limiter is kinda nice. but not the way your thinking. more like in a launch control situation. with the programming capacity you can also run a lot of timing in the lower rpms then take it out as the bike rev's. When you say dome design does that mean volume? Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
