kennethbrantley5 Posted December 10, 2015 Report Share Posted December 10, 2015 Could some please tell me which 4mill crank would be better a long rod or a short rod? And why? Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 10, 2015 Report Share Posted December 10, 2015 Long rod. Less side load on the piston against the wall. That will keep the bore true and not egg it out as quick. Quote Link to comment Share on other sites More sharing options...
kennethbrantley5 Posted December 10, 2015 Author Report Share Posted December 10, 2015 As far as the power does a long rod have a little more power? Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 10, 2015 Report Share Posted December 10, 2015 Supposedly they make more tq. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 10, 2015 Report Share Posted December 10, 2015 Increased dwell. Quote Link to comment Share on other sites More sharing options...
kennethbrantley5 Posted December 11, 2015 Author Report Share Posted December 11, 2015 The reason I asked I found out my brother is running a 4mill short rod in which he had it for about 3+ years now. I'm wondering the reliability of them because I love the way his shee turns up and bottom end torque. Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
J-Madd Posted December 11, 2015 Report Share Posted December 11, 2015 Less weight. The lighter rod is easier to accelerate and decelerate each stroke. This is not to be confused with flywheel weight. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted December 11, 2015 Report Share Posted December 11, 2015 that could be made into a PRO and CON though.. some could benefit with the added weight while others wouldnt Heavier rod is never a PRO. It has to change direction with every stroke. The flywheel is always going the same direction. That's what I meant when I said not to confuse them. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 11, 2015 Report Share Posted December 11, 2015 My bore was egg shaped after 1 hard season on a short rod. I've gone 3 easy on my long rod and haven't dropped much if any compression. Quote Link to comment Share on other sites More sharing options...
