Craig B Posted December 9, 2015 Report Share Posted December 9, 2015 Anyone have a good starting point on jetting for my combo? Stock bore & stroke SLP pipes stock carbs with K&N pod filters cool head w/ 19 cc domes [race gas] + 4 timing plate V-force 4 reeds Sea level @ Temp 30 to 50 degrees Thanks. Quote Link to comment Share on other sites More sharing options...
JasonB Posted December 9, 2015 Report Share Posted December 9, 2015 I don't have input on jets but are your cylinders ported? Aside from race gas you're going to be running the same set up im putting together. I'm interested in the SLP pipes but haven't found much info about their performance on non stroked/unported motors Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Craig B Posted December 9, 2015 Author Report Share Posted December 9, 2015 No porting as of now. Not sure if I will just port or port and big bore. I guess I will see how this current combo runs and take it from there. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 9, 2015 Report Share Posted December 9, 2015 27.5 290 run the air screw in .5 out. One clip down from the mid. This will be rich. But it should run. You can go from there tho Quote Link to comment Share on other sites More sharing options...
ECshee Posted December 9, 2015 Report Share Posted December 9, 2015 27.5 290 run the air screw in .5 out. One clip down from the mid. This will be rich. But it should run. You can go from there tho Looka this guy Quote Link to comment Share on other sites More sharing options...
Craig B Posted December 9, 2015 Author Report Share Posted December 9, 2015 27.5 290 run the air screw in .5 out. One clip down from the mid. This will be rich. But it should run. You can go from there tho I think your close. When I talked to SLP they said 290 main also. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
