The Noob Posted December 8, 2015 Author Report Share Posted December 8, 2015 Less air/more fuel is rich, more air/less fuel is lean. So any time you restrict air flow you are leaning it out So if your saying less air/more fuel is rich (less air coming from air box lid on) which is restricting airflow how can that be leaning it out ? That's why I'm confused! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted December 8, 2015 Report Share Posted December 8, 2015 You don't alter airflow to compensate for jetting. You alter jetting for your setup. Quote Link to comment Share on other sites More sharing options...
The Noob Posted December 8, 2015 Author Report Share Posted December 8, 2015 The main reason I'm asking this question is my relatively stock bike seems to be more responsive off idle in the garage with the airbox lid on. I want to try it out on a full ride but don't want to blow up my motor, so I want to be absolutely sure that running with the air box lid WON'T lean the bike out & I'm too stupid to figure it out on my own.. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 8, 2015 Report Share Posted December 8, 2015 The main reason I'm asking this question is my relatively stock bike seems to be more responsive off idle in the garage with the airbox lid on. I want to try it out on a full ride but don't want to blow up my motor, so I want to be absolutely sure that running with the air box lid WON'T lean the bike out & I'm too stupid to figure it out on my own.. You said it not us... Do a leaktest let us know how that checks out Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
tfaith08 Posted December 8, 2015 Report Share Posted December 8, 2015 Are you not reading some of the suggestions? Furthermore, what pipes are you running?Order every size main jet from 240-330. Leak test, clean carbs, set floats as per manual, sync carbs, oil filter, install 27.5 pilots (have 25s on hand), screw to 1.5 out. We will provide main jet size recommendations after you give us an elevation (google "12345 elevation", replace 12345 with your zip code) and pipe info. The items in green aren't cool little tricks or some dumb shit, they're very important steps that are crucial to tuning and the continued function of your engine. I would advise performing all of them. You shouldn't be just trying things to make them work. It's a very definite adjustment method and not a trial and error ordeal. Each fuel circuit will present with symptoms that are very specific once they are out of proper adjustment. As for the pilot being 25-30, I always bump mine up one size intentionally so that I can have a little extra fuel coming in after I have to drop the throttle to fully closed after being at WOT for extended periods of time. I make active efforts to avoid that situation off the track, but I can't tack extra seconds on a lap time becuase I want to baby my engine. Quote Link to comment Share on other sites More sharing options...
The Noob Posted December 8, 2015 Author Report Share Posted December 8, 2015 All those have been done WITH Fmf fatties.. LID ON... will I be running leaner or richer.? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 8, 2015 Report Share Posted December 8, 2015 More fuel= richer More air= leaner Quote Link to comment Share on other sites More sharing options...
The Noob Posted December 8, 2015 Author Report Share Posted December 8, 2015 So less air (lid on ) is more fuel .....which is richer ?? I know this is as dumb as dumb gets...That's why the call me The Noob Quote Link to comment Share on other sites More sharing options...
The Noob Posted December 8, 2015 Author Report Share Posted December 8, 2015 So the bike will be running richer with the lid on... CORRECT. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 8, 2015 Report Share Posted December 8, 2015 So the bike will be running richer with the lid on... CORRECT.Yes. Quote Link to comment Share on other sites More sharing options...
The Noob Posted December 9, 2015 Author Report Share Posted December 9, 2015 Thanks so much Sheer Quote Link to comment Share on other sites More sharing options...
