One pipe seems to be smoking more than other?
Buster91dg
Well the clutch side crank seal will cause that side to smoke more if it's bad, a leakdown can sqhate that away. Those plugs look terribly rich that's why I said ride it hard and clean the plugs up, jetting damn close for summer , winter I would have a 280 main at least . So I would ride it hard and try not to sit there idling it so plugs don't load up then pull em n post pics
  • Replies 47
  • Created
  • Last Reply
Top Posters In This Topic
Maybe I'm not getting the issue here. Is there A problem with it or it runs fine . Your counter acting everything said so ride it like you stole it if it's starts to get hot, lean pop feels like its laying over down on power look up leakdown test on the forum . You can make a tester cheap
Ok I'll have to do that and it runs great it's not running lean at all I was just concerned bec one pipe was smoking more than the other I just wanted to know if that's ok bec I looked up vids of what it looks like if you have a bad crank seal and it plums smoke I just wanted some opinions on what my issue is if it's a major problem or normal
Yeah I'll have to try tht I mean the thing runs solid fast and real strong. Iike I said idk the history of it I pretty much got it in a box and rebuilt the motor now I'm trying to work the kinks out of it and I was worried and was thinking it was burning tranny oil it doesn't smell like gear oil just smells like yamalube. But I'm taking it riding tomorrow I will def post pics of the plugs after riding
Could be simple as that , pay attention to the plugs , they should be chocolate not black but if your idling it like crazy plug pics are squewed. Look up plug chop procedure and post results of that . There's three three things I do to new motors than can save a lot of heartache
Compression test
Pressure/leakdown test
Plug chop
If everything checks out with that you have a solid base to tune off, ohm your plug caps if you havnt
Full throttle plugs chops only read main jet. Dialing the carbs off idle is a completly different thing. It can run good past half throttle and have good plugs. But lean on 1 side due to slides out of sync, a/f screw adjustment, pilot might be dirty, idle screws holding up a slide etc.. but all that might be a lil complicated for you at this time
Oh yeah def is I'll ride her open throttle today I really never got too and I had the carbs completely apart and they are spot less
