Pingle Fitting
Chukkinsod
I learned the hard way that there are two different sized ends to Pingle petcock. The hole in my drag tank looks like 3/8 but the Pingle I got has 1/4 threaded. I was just going to insert a reducer so it will thread into my tank. Anyone know what type fitting is not corrosive with Alchy? Not sure if it will corrode brass.
Pulled it apart and found an oring twisted in the 90 degree barb fitting. Surprised that the 90 was just pressed in no threads so pulled apart replaced oring pressed back in with vise...good to go. Just a viton brow oring in there on each side sealing the ball valve. Thanks for the help!
  • 3 years later...
