kennethbrantley5 Posted December 5, 2015 Author Report Share Posted December 5, 2015 I was told that if you have stock carbs with a 4mill that if you stay in the throttle to long that you can suck the fuel out the bowls of your carbs and blow the engine? Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted December 5, 2015 Report Share Posted December 5, 2015 I bought DriveLine billet bowls for my bike. There cheap, quality, and you can change jets without removing the bowls. Buy them. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted December 5, 2015 Report Share Posted December 5, 2015 As long rod is my favorite trail motor I've recently done few and love them power wise very similar , on my but dyno they rev better, I couple that with lite piston combo . I've never had a stock bowl run dry , as lond as your float heights are on shouldn't have an issue, also make sure your gas cap is venting properly I tend to gut all caps Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 5, 2015 Report Share Posted December 5, 2015 ^^^^ This fucker put together that long rod that is up my ass. Our set ups are exactly the same aside from the stroke and domes. Quote Link to comment Share on other sites More sharing options...
kennethbrantley5 Posted December 5, 2015 Author Report Share Posted December 5, 2015 sheerider11 do you think if I put a top end job and a aggressive port job with 19cc domes on my stock crank that would be all the power I need for what I do? Sent from my SM-N910V using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 5, 2015 Report Share Posted December 5, 2015 sheerider11 do you think if I put a top end job and a aggressive port job with 19cc domes on my stock crank that would be all the power I need for what I do? Sent from my SM-N910V using Tapatalk If it's your first bike then yeah. But I'm a big advocate for doing it once right the first time. I say buy once cry once. So I'd say you need your crank inspected and welded for sure, trans done, clutch done, reeds inspected, bike gone over for anything else that may be over looked. There's a lot of seasonal parts on these bikes that people tend to just never replace. Also know that 19cc dome will require race fuel. So make sure your willing to commit to that. Unless your way up in the mountains. But you still need to get the ratio and other things. That's where an experienced builder comes into play. Quote Link to comment Share on other sites More sharing options...
kennethbrantley5 Posted December 5, 2015 Author Report Share Posted December 5, 2015 Yes it is my first bike but my thinking is like yours buy once cry once. I put my coolhead, vf4reeds, T5's, and K&n pods on at once. Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 5, 2015 Report Share Posted December 5, 2015 Yes it is my first bike but my thinking is like yours buy once cry once. I put my coolhead, vf4reeds, T5's, and K&n pods on at once. Sent from my SM-N910V using Tapatalk Where are you located? Maybe your close to someone that can guide you I the right direction. It's hard to judge parts you can't see Quote Link to comment Share on other sites More sharing options...
kennethbrantley5 Posted December 5, 2015 Author Report Share Posted December 5, 2015 I'm in Northwest Florida. Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted December 6, 2015 Report Share Posted December 6, 2015 I'm pretty sure I could set you up on a stock crank and the bike would scare you . Yes for what u do an appropriate port job domes for intended fuel and a good bore/hone/Pistons will leave you ahead of your competition Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 6, 2015 Report Share Posted December 6, 2015 I'm pretty sure I could set you up on a stock crank and the bike would scare you . Yes for what u do an appropriate port job domes for intended fuel and a good bore/hone/Pistons will leave you ahead of your competitionThis. Not gonna throw out any names but I've beat a handful of sponsor built and backyard built bikes. Quote Link to comment Share on other sites More sharing options...
kennethbrantley5 Posted December 6, 2015 Author Report Share Posted December 6, 2015 sheerider11 I forgot to ask you are going to make it to the April ride in Ga. Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
kennethbrantley5 Posted December 6, 2015 Author Report Share Posted December 6, 2015 With a aggressive port job how can I not lean it out and grenade it. Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 6, 2015 Report Share Posted December 6, 2015 sheerider11 I forgot to ask you are going to make it to the April ride in Ga. Sent from my SM-N910V using Tapatalk No its like a 22 hour drive Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted December 6, 2015 Report Share Posted December 6, 2015 Jet it according Quote Link to comment Share on other sites More sharing options...
