BANSHEERSA Posted December 3, 2015 Report Share Posted December 3, 2015 I have a t-rex w/cool head 72mm bore ported polished 38 mm carbs drag pipes +10 swingarm 18 tooth frt 38 tooth rear v-force reeds 20 inch tires slicks twist throttle air shift advanced timing +4 running on 110 . So my question is. . What do i need to do to go faster? I Drag race 1/8 mile asfault Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted December 3, 2015 Author Report Share Posted December 3, 2015 Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted December 3, 2015 Report Share Posted December 3, 2015 how fast are you now Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted December 3, 2015 Author Report Share Posted December 3, 2015 Well the track said 97 but my gps on my phone said 104.47 Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted December 3, 2015 Author Report Share Posted December 3, 2015 I need to be quicker Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted December 3, 2015 Report Share Posted December 3, 2015 i meant time not trap speed Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted December 3, 2015 Author Report Share Posted December 3, 2015 Oh my bad so far nt to great ive had bad starts and have only run it 6 times but im doin bout a 7 sec 1/8 Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 3, 2015 Report Share Posted December 3, 2015 60'? Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted December 3, 2015 Report Share Posted December 3, 2015 derp.. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted December 3, 2015 Report Share Posted December 3, 2015 Clutch set-up? What gear you starting in? Are you wound out in whatever gear when you cross the line? Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted December 3, 2015 Author Report Share Posted December 3, 2015 Start out n 1st and still got pull past finish line direct drive racing clutch Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 4, 2015 Report Share Posted December 4, 2015 Stock clutch set up? Stock trans? I'm not into drag racing but I see a lot of wieght you can cut. Quote Link to comment Share on other sites More sharing options...
possum Posted December 4, 2015 Report Share Posted December 4, 2015 Ffs Quote Link to comment Share on other sites More sharing options...
BANSHEERSA Posted December 4, 2015 Author Report Share Posted December 4, 2015 Ya i know the weight i can cut alot ive just got the bike nt long ago so im wanting to do sum things to it just hvent had time yet &possum no its nt stock dnt know exactly what is n the trans and clutch the guy (works for yamaha) i bought it from nhad told me but i cnt remember ima go get it dyna 1st of the yr im gettin another frame. Then gonna chop it up and cut all the weight then throw the motor n it. I jus want to know sum ideas of what i can do to get it to go faster/ quicker thx for all the help Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
SlowerThanYou Posted December 13, 2015 Report Share Posted December 13, 2015 I have a t-rex w/cool head 72mm bore ported polished 38 mm carbs drag pipes +10 swingarm 18 tooth frt 38 tooth rear v-force reeds 20 inch tires slicks twist throttle air shift advanced timing +4 running on 110 . So my question is. . What do i need to do to go faster? I Drag race 1/8 mile asfault Ok well what bout 1/8 asfault? What sprockets ? I currently have 18-40 T-rex cpi's air shift 72mm pistons and 19-8-10 tires slicks getting sum American Racers soon cuz im nt gettin the hook u need You are conflicting on the information you are giving. What's the gearing, 38 or 40 rear teeth & what size tire, 20" or 19" diameter? Quote Link to comment Share on other sites More sharing options...
