Time Machine Posted December 3, 2015 Report Share Posted December 3, 2015 I keep learning. Borrowed a leak down tester a couple weeks ago and the engine failed. Lost 1 1/2 pounds a minute. Decided to make my own tester and try it again. Tested it this morning and it passed. Held 6 pounds for over 5 minutes, needle didn't budge. I used a bunch of Windex on that first test, including on the tester, didnt see any leaks on it. One thing I did differently this time was to really clean up the exhausts before I put the caps on. I checked them on the first test, but it's hard to see well up there, so I'm wondering if that's what I missed. Anyhow, after doing some reading here I decided to use a fuel pressure gauge for the tester. I bought this Mr. Gasket, #1561, for $18 at O'reilleys. Quote Link to comment Share on other sites More sharing options...
Power_Man Posted December 3, 2015 Report Share Posted December 3, 2015 Looks good to me. i had it happen once, that it lost a bit. took it all off and sprayed some silicone/oil on all the joints to get a good seal and then it didn't drop any. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted December 3, 2015 Report Share Posted December 3, 2015 Could've been a cheap/ shitty air pump. sent from yo mammy house. Quote Link to comment Share on other sites More sharing options...
Guest XDOVAYA Posted December 4, 2015 Report Share Posted December 4, 2015 Ok cool so you can leak down test with motor in the frame, something I still need to do. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted December 4, 2015 Report Share Posted December 4, 2015 Ok cool so you can leak down test with motor in the frame, something I still need to do.Ffs 1 Quote Link to comment Share on other sites More sharing options...
