sleeper06 Posted November 30, 2015 Report Share Posted November 30, 2015 The way I'm reading it he smashed too much air in there and there a weak seal or he blew it out , if that keyway is leaking it's gonna leak constant and won't stop when you get to 6psi it will continue to leak Quote Link to comment Share on other sites More sharing options...
mtsnieg Posted November 30, 2015 Author Report Share Posted November 30, 2015 I know how to let things serup. I knew the 1 hour comment would bring out the usual dickhead comments, and it did. I punped in the air with a hand bicycle pump. Got it up tu 9 or 10 pounds, which every two stroke Ive owned has held pressure at. Now as I said earlier I was having problems with oil blowing out the overflow before I touched the quad. I asked for advise, and got smart asses. Not meaning to comain, but its par for the course. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted November 30, 2015 Report Share Posted November 30, 2015 Get dish soap n water spray in that area as your pumping Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted December 1, 2015 Report Share Posted December 1, 2015 9-10 is alot.. jmo. And i seal mine till it hold the 100%.. no leaks. . Got to much $ in this dam thing to let there be a leak. . I test to 7psi Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 1, 2015 Report Share Posted December 1, 2015 Where do you pump the air in at? The small fiting on the head? Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted December 1, 2015 Report Share Posted December 1, 2015 Where do you pump the air in at? The small fiting on the head?Yea... Quote Link to comment Share on other sites More sharing options...
possum Posted December 2, 2015 Report Share Posted December 2, 2015 Oh geez.. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted December 2, 2015 Report Share Posted December 2, 2015 Where do you pump the air in at? The small fiting on the head?Where the fuck else would you pump it up? Quote Link to comment Share on other sites More sharing options...
rubberneck Posted December 2, 2015 Report Share Posted December 2, 2015 arent you supposed to pump it in the little check plug on the side of the cylinders? Why else would that be there? Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted December 2, 2015 Report Share Posted December 2, 2015 pump it up witcha lips bro... Quote Link to comment Share on other sites More sharing options...
