Air pressure in clutch cover
mtsnieg
I was doing some wide open throttle plug shots yesterday cold weather here getting the Banshee set up for ice. Yesterday I noticed a small amount of oil coming out of the breather overflow tube Didn't think much about it figured it was over filled the little bit. I just got done doing a couple more runs and plug chops and went to check the oil And was air pressurized Not horribly but I can hear the pressure relief soon as I lifted the dipstick. That would bleed the clutch side Crank seal leaking correct? Engine only has a month or so on complete overhaul crank top end Seals and it passed the sound test perfectly then. Just looking 4 in but I guess I will Strip the pipes and carbs off to a leak down test here
Just did a pressure test get 10 pounds in it and it pisses off of the clutch side crank seal bearing it sounds like until the gage gets down to six ounce then it hold steady six ounce bumper back up the 10 pieces out Down to 6 hold 6 pounds should i restart the sprocket with the spacer on that side seal maybe it came loose
Tested and retested and retested anything about six and a half pounds at leats comes down to six and a half 6 pounds and hold steady Forever. Leaks out from behind the primary gear crank seal is this normal or is this okay. On my Honda and Suzuki two strokes are usually make sure they hold closer to 10 pounds for at least 5 minutes. I manually blown with my own mouth through all the vent lines for the tranny case and clutch case and they all breathe freely so that's not clogged.
Sent from my C6730 using Tapatalk
What is the sound test? Check the little breather under the rear motor mount.
