trickedcarbine Posted December 15, 2015 Report Share Posted December 15, 2015 As long as everybody here is in to Two Strokes. 1 Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 16, 2015 Author Report Share Posted December 16, 2015 What do you mean?? hole in the light smaller and not munch material to make it bigger?? The hole is the right size just not in the right location. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 16, 2015 Report Share Posted December 16, 2015 The hole is the right size just not in the right location. Sent from my iPhone using Tapatalk The side if the outside case is hitting the bracket when trying to align the holes? Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 16, 2015 Author Report Share Posted December 16, 2015 The side if the outside case is hitting the bracket when trying to align the holes?Yes it is too wide, just barely. I will have to cut about 1/16 inch off of each side, then I will have to figure out the depth issue. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 16, 2015 Report Share Posted December 16, 2015 Yes it is too wide, just barely. I will have to cut about 1/16 inch off of each side, then I will have to figure out the depth issue. Sent from my iPhone using Tapatalk Maybe making a bigger hole on the bracket and fit an offset bushing? Shit, i'm looking forward to get mine!! Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 16, 2015 Author Report Share Posted December 16, 2015 Maybe making a bigger hole on the bracket and fit an offset bushing? Shit, i'm looking forward to get mine!! I would like to keep from modifying the bike to fit a light. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted December 16, 2015 Report Share Posted December 16, 2015 Idk how particular you're trying to get but what about two small plates that mount to the outside of the existing headlight mounts that are roughly an inch tall and wider than the stock location, then mount it between those brackets? Kinda mickey mouse but it would work without modifying the lights or the stock headlight mounts. 2 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 16, 2015 Report Share Posted December 16, 2015 (edited) Ok, just came back from the electrical dep. They made me a new nice plan, but it's more complicated... Edited December 16, 2015 by Santa Claude Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 16, 2015 Author Report Share Posted December 16, 2015 Idk how particular you're trying to get but what about two small plates that mount to the outside of the existing headlight mounts that are roughly an inch tall and wider than the stock location, then mount it between those brackets? Kinda mickey mouse but it would work without modifying the lights or the stock headlight mounts. That's what I was thinking but I would rather modify to fit.... Idk I might disassemble the housing today to see if I can cut into the housing to give clearance for the mount Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted December 16, 2015 Report Share Posted December 16, 2015 ^^. Making something simple... Complicated Quote Link to comment Share on other sites More sharing options...
banshee#527 Posted December 16, 2015 Report Share Posted December 16, 2015 That's not an electricians that's an electrical engineers design! They always make something simple so complicated. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 16, 2015 Report Share Posted December 16, 2015 (edited) Wtf is all this shit? You can ditch almost all that. Sorry, but no. I had big peak voltage with the 'simple' way. So he added the voltage regulator (78L12) and add the transitor (2n3055) to make it a real PRO job. And btw, this is far from a complex circuit. About 20$ of parts... Should have it done by tomorow. Edited December 16, 2015 by Santa Claude Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 16, 2015 Author Report Share Posted December 16, 2015 Sorry, but no. I had big peak voltage with the 'simple' way. So he added the voltage regulator (78L12) and add the transitor (2n3055) to make it a real PRO job. And btw, this is far from a complex circuit. About 20$ of parts... Should have it done by tomorow. Question is can you put it in a housing to actually make it a practical application? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 16, 2015 Report Share Posted December 16, 2015 (edited) Question is can you put it in a housing to actually make it a practical application? Sent from my iPhone using Tapatalk Sure, will show you the finished product in a day or two. Exams period here, so i'm little bit more busy than usual. Edited December 16, 2015 by Santa Claude Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted December 16, 2015 Report Share Posted December 16, 2015 $55 will get you a podtronics rectifier/regulator that will handle up to 200w. One compact unit with 4 wires. Just sayin Quote Link to comment Share on other sites More sharing options...
