mtsnieg Posted December 20, 2015 Report Share Posted December 20, 2015 Sent from my C6730 using Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted December 20, 2015 Report Share Posted December 20, 2015 Sent from my C6730 using Tapatalk So how are you running them? With battery and DC conversion, or something else? How bright are they? Shoot out far? Quote Link to comment Share on other sites More sharing options...
mtsnieg Posted December 20, 2015 Report Share Posted December 20, 2015 I have them soldered to the stock headlight wires. Nothing else, using stock switch, low or high they come on. Bright white light. But not sure if I'm gonna like them. 30 degree spot beam 27 watts each. Doesnt seem to light out far, and not wide around the quad in front. I'm gonna get it in the barn today where its dark and try to get em aligned better, I was loaded last night. Then maybe hook the stockers back up so I have a good sober (hopefully) comparison. I have some blue 'brighter' bulbs in my stockers that seemed way better than stock bulbs. Is there a resistor in the stock light switch? Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 20, 2015 Author Report Share Posted December 20, 2015 I have them soldered to the stock headlight wires. Nothing else, using stock switch, low or high they come on. Bright white light. But not sure if I'm gonna like them. 30 degree spot beam 27 watts each. Doesnt seem to light out far, and not wide around the quad in front. I'm gonna get it in the barn today where its dark and try to get em aligned better, I was loaded last night. Then maybe hook the stockers back up so I have a good sober (hopefully) comparison. I have some blue 'brighter' bulbs in my stockers that seemed way better than stock bulbs. Is there a resistor in the stock light switch? What did you do to the housing for them to fit? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
mtsnieg Posted December 20, 2015 Report Share Posted December 20, 2015 The light housing I had to trim about an eigth of an inch off each side, all the way up to the curvature of the light. Quik work with a cut off wheel. Still had to trim the stock mounts an can been seen in above pic. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted December 20, 2015 Author Report Share Posted December 20, 2015 I'm not too big of a fan with pictures of light pattern but I ordered 1 spot and 1 flood light so hopefully once I get these brackets from corgster these lights will be worth it Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
mtsnieg Posted December 21, 2015 Report Share Posted December 21, 2015 The first pic is at idle, second is with a little throttle. Looking at the pics on my computer here they look bright. But it was still light out though the barn doors were shut. They don't throw a lot of light out front aways. I ordered 30 degree spot and the seem like a flood. I re wired the stockers back up with the blue bulbs and I had a nice spot on the other sid. Yellow light but definitely farther. The leds were bright ass crisp white. Come springtime when I'm gonna need this light for trailriding I will probably do the trailteck rectifier and battery and some decent leds. I see jds has some great prices right now, but not top on priority list this time of year, for the shee. Quote Link to comment Share on other sites More sharing options...
Dixie normus Posted December 21, 2015 Report Share Posted December 21, 2015 I like these pretty well Quote Link to comment Share on other sites More sharing options...
Dixie normus Posted December 21, 2015 Report Share Posted December 21, 2015 36w total Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted December 21, 2015 Report Share Posted December 21, 2015 Since your feeling so giving this season I'm looking to have a new press plate machined to split cranks apart the one I have now works but it's very rough , I would love to have one that's true n square this way cranks press apart nicer Carl do you have a sketch or blueprint of what you need? Do you know Pak's Machine in Hicksville, he's an old timer that's got skills beyond skills lemme know what you need I deal with him! I can get you whatever you need!!! Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 23, 2015 Report Share Posted December 23, 2015 Job for Willa is done! Here is his bracket 3 Quote Link to comment Share on other sites More sharing options...
Sandking Posted December 23, 2015 Report Share Posted December 23, 2015 Job for Willa is done! Here is his bracket Those look great 2 Quote Link to comment Share on other sites More sharing options...
possum Posted December 23, 2015 Report Share Posted December 23, 2015 Santa Claude = best engineer/machinist on HQ Quote Link to comment Share on other sites More sharing options...
