What is the proper way to plug chop? Do I have to coast after shutting off? Or can I slam on anything that looks like a brake? Use new plugs or old ones? How long do I need to be in sixth gears ass?
Get it wide open for a few seconds in 6th gear ,pull the clutch in and shut it down while in motion. You can coast or brake. As long as the clutch is pulled in, it doesn't really matter. Pull the plugs, and give them a view. You'll know if it's close. If the plug is wet and clean, don't bother even cutting it open. If it hesitates, pops, or pings don't keep trying to get it to rev out.
  • Like 2
I always warm up engine real good on old plugs, change to new gapped plugs at start of my straightaway. As soon as I start bike take off through all gears hold sixth for 3 -1 thou then with throttle stil wide open pull clutch and kill ignition , coasting n breaking doesn't matter
In 14 years of owning Banshees I've never done a plug chop. They are totally unnecessary in my opinion.
Plug chops and leak down tests. Never done either of them. Proper assembly, jet it close and fine tune it in from there. JMO
  • Like 3
Plug chops are only a part of the tuning regiment but I've done a ton over the years in our gas motors. It's likely more beneficial to me as an asphalt racer running WOT because it's a great indicator of the main circuit. My motors build heat throughout the run and by the 1/4 mile traps are reaching meltdown points. I don't do them near as often but for sure at the start of each season or anytime I make setup changes I'll throw one cheap ES plug in my hottest cylinder and check things.
I'm in the same regiment as Tedder and quite honestly I do them on 90% of my customer builds its peace of mind to me to chop it perfect on knats ass then put 2 sizes up on the main for idiot factor
  • Like 1
