Well, I am completely parting out my 421 Cub. I built it in late 2012-ish, broke in the engine, went to Glamis once then parked it for roughly 2.5 years. Life happened, just havent had the time to go riding and have gone into the deep end of track days and slippery slope of constantly throwing money at my car for better lap times. The bike sat out side, and certain parts show damage from sun and weather (rust) and have been priced accordingly. All prices are OBO, buyer pays shipping. Small parts that I have F/S, will be let go for the cost of shipping as indicated.
Since there is alot of stuff F/S, I will send more detailed pictures upon buyers request.
Engine - From what I remember, the engine ran flawless the last time I rode it 2+ years ago. A few weeks ago the bike would not turn over. A few days ago there was a lot of liquid in the right pipe. The cylinders will need replating due to the damage on the right cylinder. Rod bearings feel fine as well as the crank bearings. The top case has slight chain wack, but nothing major. Transmission operated as it should.
1-5 N down Dunable Override - 250
Crank Cases - 100
39mm Carbs setup for GAS w/ filters - 250
39mm billet manifold - 75
vf3 reeds - 125
Chassis parts - Frame is PC'd Trans Purple and lightened w/ bolt on subframe by Tim at Stellar. Bought the frame from Tim back in '09 and has not been wrecked. There is a spot of PC missing in the front of the frame. Frame is straight and titled, I would prefer local pickup but can ship at buyers expense via grey hound. The J-arms will need ALL ball joints replaced. The Direct Drive spindle mounts will need bearings replaced and need new valve stems. The tires are old, but dont show dry rotting and hold air. The swingarm has a crack behind linkage mounting point and discounted accordingly since it will need to be repaired, or will end up in the trash if nobody wants it.
Lightened frame w/ subframe and title; Frame is straight, a small area of pc missing in the front. I would prefer local pickup but can ship at buyers expense via grey hound- 500
Marvin Shaw13.5” rear Coilover - 175
Chrome Steering stem - 75
renthal handle bars - 40
chrome footpegs; rusted in certain areas - 50
polished linkage - 50
Sold list-
4mm crank
Billet clutch basket
lightened flywheel
timing plate
IGN coil
Stator Cover
Billet Dipstick
Marvin Shaw Front Hillshooters
Stellar J-arms
Brake pedal
Gear Slammer
+8 LSR swingarm
Billet rear brake cap
Parking brake block off
Water pump cover
Clutch lever
Kick starter
Chrome throttle assy
Spindle mounts
Rear Brake line
Shearer inframes
JJ&A Axle
421 cub cyl
chariot head w/ domes
Direct Drive lockout w/ clutch cover
Due to the holidays, I will not be able to ship as immediate as I have in the past.
IMG_0271_zpst0eguafv.jpgIMG_0270_zpseuheyova.jpgIMG_0269_zps7jiompgb.jpgIMG_0268_zps6fev7qn2.jpgIMG_0267_zpsu3felhyi.jpg
Edited by r/atvshee
