best pipes for my build
Green has made a lot of good points along with some others in this thread. Also you can just throw a normal set of shearers on your bike.
1 because it's not gonna perform good with your setup
2 the normal stinger tubes will not fit with a air box and you will have to have them custom made to fit.
Seems like your falling into the category of wanting more power. Fist thing first though especially for a trail bike, you need good suspension. You'll be able to ride faster with a good suspension setup. After suspension is done then you get the a bigger motor ( or both if you got a lot of coin to drop) remember a bigger motor with more power will drink more gas though so keep that in mind also
when i dynoed mine, i ran fmf vs shearer, both made the same peak power but fmf came on sooner and had more torque. the 2:1 wasn't able to give enough fuel for the higher rpms (even with a billet bowl)
This was with that mid 60's HP trail motor right?
http://slp.cc/catalog.cfm?pageID=detail&catalogID=11&productID=1703
There was some dyno runs vs fmf. I am trying to dig them up. I believe it was 8hp difference.
http://www.jdscustoms.com/product/slp-yamaha-banshee-pipes/#
It was 6 over cpi's, so I will stand by 8-10 over fmf.
