  • Replies 43
  • Created
  • Last Reply
Top Posters In This Topic
Something must be frikd with the gas line because i pulled it off the "problem carb", and turned the fuel on and, no fuel came out that fuel line but, it was still running to the other carb...must be the T connector is bad or something...
Sent from my LGLS990 using Tapatalk
Shees alive! Well it turned out that the petcock filters were plugged..and so the little bit of fuel that made it through, followed the gas line to the "T" connector and than would run strait to the right side carb(path of least resistance). since the "T" kind of angled that way.
Cleaned it out and shee fired up and runs purty decent.
Will have some fine tuning to do...
Thanks to u guys that commented and helped! Appreciate it. Sometimes the most confusing obstacles are the simplest fix
^ for what?
Figured he would out of curiosity. Maybe another thread, but I thought he said he was ripping on it really hard.
sent from yo mammy house.
  • 1 month later...
You must have a clogged gas line it has happend to me I would install new gas lines there cheap at any auto store also check the inlet were the gas line plugs in anything there I bet when u replace that shit u should be good To go
