Dome size
Andreb84
I had 22cc domes on it before and i ran it on pump...that had the compression somewhere in the 140s...trying to get a little more compression without having to pay 10$ a gallon for gas
You are pretty much right on the edge with that combo. Just because you get a static kicking compression of 140, doesn't mean it's really that safe. With Cub Cylinders they have a larger exhaust area and it allows some AFM to escape before the piston totally compresses the mixture and is fired. That translates to what "appears" to be a lower compression ratio.
