sleeper06 Posted November 13, 2015 Report Share Posted November 13, 2015 Nikasil is a great product, keep up on maintaining top end with compression tests every 20 hrs once compression drops 5-7 psi or differs side to side change rings , my cousins 421 alky cub hasn't been apart in 7 yrs , I've see a 3 lb diffrence in that time 2 Quote Link to comment Share on other sites More sharing options...
Darkblade Posted November 14, 2015 Author Report Share Posted November 14, 2015 Nikasil is a great product, keep up on maintaining top end with compression tests every 20 hrs once compression drops 5-7 psi or differs side to side change rings , my cousins 421 alky cub hasn't been apart in 7 yrs , I've see a 3 lb diffrence in that timecan i run the driveline cylinders on stock carbs and fmf gnarly pipes Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted November 14, 2015 Report Share Posted November 14, 2015 FFS^ best post in this thread 1 Quote Link to comment Share on other sites More sharing options...
JTmachining Posted November 14, 2015 Report Share Posted November 14, 2015 I'm not sure why you quoted me? Quote Link to comment Share on other sites More sharing options...
817DMX Posted November 14, 2015 Report Share Posted November 14, 2015 You get it replated if it's even bad, you do not want iron sleeves, they wear out faster, it holds heat, it has more friction, nic plating is a lot harder, less friction, lasts , and your rings last longer, you will free up a few hp just having plated cyl, from less friction. When guys on here are trying to guid you the rite way, listen especially when you obviously don't have a clue, the driveline cyl are going to save you in the long run, far better cyl, Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 14, 2015 Report Share Posted November 14, 2015 I've personally seen the Driveline cylinders run. I know Bill has them dialed. Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted November 14, 2015 Report Share Posted November 14, 2015 Who here has a set of niche cylinders? Who here actually seen a niche person active on the site? There is a reason people support driveline over niche. Niche is a nobody in the banshee world. Driveline has been around for a while and Bill is actually an active person in the banshee world. I have two sets of niche cylinders. Both unported and one set never bolted up. Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted November 14, 2015 Report Share Posted November 14, 2015 I'd try a set of drivelines before I bought another serval. Quote Link to comment Share on other sites More sharing options...
gusto Posted November 14, 2015 Report Share Posted November 14, 2015 Drive Line cylinders sent to Redline 1 Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted November 14, 2015 Report Share Posted November 14, 2015 I'd try a set of drivelines before I bought another serval.That's not really a fair statement towards the serval cylds. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted November 14, 2015 Report Share Posted November 14, 2015 (edited) I'd try a set of drivelines before I bought another serval.I thought you scooped up a serval top end. Were you not impressed? sent from yo mammy house. Edited November 14, 2015 by bigweav81 Quote Link to comment Share on other sites More sharing options...
possum Posted November 14, 2015 Report Share Posted November 14, 2015 Here we go! 1 Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted November 15, 2015 Report Share Posted November 15, 2015 FFS wheres the epic face palm emoji? Gravel take your geritol, and blood pressure meds......., and chill the Fuck out lol. I was simply asking Dave's reasoning for his reply. I agree though. No more posting in such a stupid fucking thread lol. sent from yo mammy house. 1 Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted November 15, 2015 Report Share Posted November 15, 2015 (edited) I thought you scooped up a serval top end. Were you not impressed? sent from yo mammy house. It was ok. Ran good. I'd try the driveline stuff though. Shit it's the same price new as that one was used. If they make similar power I'd go driveline. The separate cylinder setup I like. You have an issue you can get away with replacing just one. And if I had to buy a set of stock cylinders to port I'd also go driveline. More power potential from those than a set of stockers by quite a bit. And cost is pretty well the same by the time you bore and buy pistons. Edited November 15, 2015 by dave5.0 Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted November 15, 2015 Report Share Posted November 15, 2015 It was ok. Ran good. I'd try the driveline stuff though. Shit it's the same price new as that one was used. If they make similar power I'd go driveline. The separate cylinder setup I like. You have an issue you can get away with replacing just one. And if I had to buy a set of stock cylinders to port I'd also go driveline. More power potential from those than a set of stockers by quite a bit. And cost is pretty well the same by the time you bore and buy pistons.Well said. sent from yo mammy house. Quote Link to comment Share on other sites More sharing options...
