TurnerBanshee Posted November 10, 2015 Report Posted November 10, 2015 I planing buy two, mikuni tm28 flat, but I need to know the best jetting for use these carbs? Quote
Bennett131 Posted November 10, 2015 Report Posted November 10, 2015 Depends on your motor modifications, which consist of? Quote
TurnerBanshee Posted November 11, 2015 Author Report Posted November 11, 2015 Mods: - Fmf golden series w/powercore 2 - .50 piston bore Only Quote
wayne_smith97 Posted November 11, 2015 Report Posted November 11, 2015 If those are your only mods, you have no need for bigger carbs. Quote
TurnerBanshee Posted November 11, 2015 Author Report Posted November 11, 2015 Understood, I thinking in buy bigger carbs because the stock carb are bad, and I thinking to take advantage of in put better carbs but if is unnecessary, then I buy stock carbs again Quote
Bennett131 Posted November 11, 2015 Report Posted November 11, 2015 Understood, I thinking in buy bigger carbs because the stock carb are bad, and I thinking to take advantage of in put better carbs but if is unnecessary, then I buy stock carbs againI have a set...will need the tors delete. 30 shipped Quote
TurnerBanshee Posted November 11, 2015 Author Report Posted November 11, 2015 I have a set...will need the tors delete. 30 shippedSent a pm for pics and more info Quote
Bennett131 Posted November 11, 2015 Report Posted November 11, 2015 Tapashit isn't working I'll get it tomorrow morning. 1 Quote
TurnerBanshee Posted November 11, 2015 Author Report Posted November 11, 2015 Ok i'll wait your pm for tomorrow Quote
