2into1 charriot 35mm pwk carb 188 main jet and 50 pilot usin needle the carb came with, the bike starts n idles but when you first tap the throttle it bogs until you give it gas hard enough the powerband stays with no boggin any help on the boggin would help
  • 1 month later...
Bog like: crackle pop pop or bog like you are hitting the kill switch.  With that high of main I'd say your rich bogging.  Get worse when it's hot?  I have stock bore and stroke, wiseco pistons, coolhead with 22cc, and Fatty pipes. Trinity 2 into 1 Pwk 35mm. 600 ft above sea level, 60 degrees F.
The above info is what you will need to provide if you expect to get accurate jetting advise
I have:
48 Pilot  (50 when in the 30's outside)
04 KX250 needle middle clip
170 main always.
1 1/2 turns out on the air screw
  • 3 weeks later...
i'm running 2-1 but am using 38mm pj carb.  everything went so much better after going to the larger carb.  i'd like to put on a single 41/44 lectron after i find one. i had a very specific needs with this particular bike  and the 2-1 finally achieved those needs.
  • 3 years later...
highly doubt ill get a reply.. but I got a 4mil  65.50 bore, porting, fmf full exhaust, 2-1 SINGLE carb, 19cc domes, 795 pistons. where should I start on my jetting?? im very new to this fourm
