chase@miamiatv.com Posted November 6, 2015 Author Report Share Posted November 6, 2015 sleeper if the kit is a hundred or so , wouldnt it be smarter to send to a shop ? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted November 7, 2015 Report Share Posted November 7, 2015 1.25 if you want to get technical. But there usually 8 or 10 x 1.25 1.0 or something close to that size Quote Link to comment Share on other sites More sharing options...
J-Madd Posted November 7, 2015 Report Share Posted November 7, 2015 Any reason it couldn't be tapped to a bigger and/or coarser thread and just run a bolt in it? Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted November 7, 2015 Report Share Posted November 7, 2015 Thats no a helicoil you pulled out, its just the cast threads.... youll need to buy a 8mx1.25 helicoil kit and drill bit, all the info on the size drill bit is on the package. This is a easy fix. 1 Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted November 7, 2015 Author Report Share Posted November 7, 2015 so this is what i need http://www.ebay.com/itm/HeliCoil-5546-8-Thread-Repair-M8-x-1-25-12-Insert-Tool-Complete-Kit-/271320151837?hash=item3f2bf0f71d:g:nBAAAOSweW5VefrV Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted November 7, 2015 Author Report Share Posted November 7, 2015 i snapped this photo a few days ago , this little spring like threading came out....... its not a heli coil ? it easily crumbled into tons of peices ........ Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted November 7, 2015 Report Share Posted November 7, 2015 yes, thats what you need and no that isnt a heli coil threads coming out, they are steel. the cast threads crumble like that. Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted November 7, 2015 Report Share Posted November 7, 2015 youll have to remove that cylinder to drill and tap for the heli coil Quote Link to comment Share on other sites More sharing options...
camatv Posted November 7, 2015 Report Share Posted November 7, 2015 either the cylinder has overheated or you tightened it up to much. timesert would be permanent. if your mech inclined you will find all kinds of uses for them they are much stronger but thicker than some like. you should have plenty of room to get one in there the thin wall. after its in you just need to make sure the cylinder is flat there.. before you do this put the head back on and tq every stud in the cylinders. after one starts if its an overheat issue others will follow. dont go more than 20ft lbs with a GOOD tq wrench. not that pile of shit they rent out at the parts store. and get a top end gasket set and pull it to do it. if it pulls more just take them off and toss them, get ahold of driveline and buy their top end kit.. Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted November 7, 2015 Author Report Share Posted November 7, 2015 Going to just pull the cylinders both and send them out.......... I over heated this motor ..... had the top overflow line on the head pop off ....... nearly thought the motor was going to blow up on me it was that hot... i melted the cool head stickers to a brown ......... so if one studs doing this , all the others probly are right behind too like you said...... going to rip the top end off and send the entire jugs out .... need a week or so . busy with caterings this month... I like the idea of sending them out and having it done right for a hundred or so bucks.... Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted November 7, 2015 Author Report Share Posted November 7, 2015 Thankyou all ! Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted November 7, 2015 Report Share Posted November 7, 2015 Let's put it this way , send to whoever you like just make they drill it square and countersink the sert enouph , have them check the cylinders deck for flatness Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted November 7, 2015 Author Report Share Posted November 7, 2015 sleeper who is the man you would send these off to. I trust you , you always been a major help to say the least... I might ride sunday on my other bike , so maybe mid week i will pull the jugs. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted November 7, 2015 Report Share Posted November 7, 2015 if your not in a rush , send it to me if its tight enouph for a heli coil to work that's what I'll do, if not we gotta order the setts but it's hard to say without gushing the hole 1 Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted November 7, 2015 Author Report Share Posted November 7, 2015 give me a week to rip the jugs off , im fine with waiting a month or two to get the cylinder done. ( this is my drag quad ) Ill pm you in a week or so. Thanks so much ....... I have 4 atvs right now ....... two banshees and 2 warriors. both warriors are 2002 original tires , titled bikes . with probly 15 hours on each bike ... the person i bought them off of , would take them to the shop to change the battery , thats how bad these people should not of owned a atv. I use them to get into the woods and hang out. Theyre great bikes to trail ride ... Gives my dad or a friend a extra bike to ride , and makes for easy towing of the drag banshee , everytime it breaks lol... I bought both bikes for a grand total of 2500 .... Theyre worth keeping to toy around....... Thats why im not in a hurry and i woulnt want to rush you EVER ! if your doing the work .... Nothing good ever comes out of people in a rush. Patience pays off ! Ill contact you in a week or so and we can go from there........ Thanks again , i really appreciate this. Quote Link to comment Share on other sites More sharing options...
