What could of caused this?
So I went for a ride and coolant starting leaking out the exhaust, so I just thought it was just an o'ring, opened it up and saw this a dent on the dome, what could of caused it? There's no dent on the piston. I have a 4mil, drag port v force reeds, plus 4 timing and 19cc domes, I was running c12 race fuel.
Edited by quickbansheeman
Looks like a new dome. If the dome was mint when you installed, then something got on top of the piston. You say piston has no mark/scare. When a chunk gets on top of piston and bike has run, it will leave lots of marks, not just one. Are you sure dome was perfect when it went in?
  • Like 1
This also don't look like viton orings and could have been compromised with heat in the fire ring area, I would at least pull the jug on that side and check everything out, antifreeze doesn't like to compress like fuel charge does and can put stress on parts
the Viton O-rings are the red/brown colored ones correct?
  • Like 2
