Looking for a better sprocket set up for my shee it currently has 13 up front and stock in the rear. Used to ride in Glamis but Going to LS and was wondering if it's best to run a bigger front since most racing out there is flat ground? Mods are ported cylinders, 35mm pwks, v- force 3s, T5s, lockout clutch, and a few other things
Sent from my SM-G900V using Tapatalk
i've been running 15 upfront since i only had fmf fatties and has always ran great.. you will be fine with a 15.
just buy a 14 and 15.. only like $30 ea anyway..
yes that should be fine. i always go abit longer and trim it down.
also make sure u match up the pitch.
  • Like 1
