All new MX/Trail banshee
Abe
Practically every fastener and part in the complete build is new. chassis is oem with all brackets etc.. not being used removed and fresh black powder coat, lsr +2+1 a-arms, lsr stock length swingarm, lsr +2+1 steering stem, lsr +3 axle with all lsr billet hubs including the fronts, elka stg 3 shocks front and rear, jds rotors front and rear, stainless braided lines front and rear, hiper tech 3 wheels with pulse tires, ac mx pro peg nerfs, ac front bumper, pro taper atv low fat bars, asv levers, cascade shorty gear slammer shifter, chariot new design billet throttle, clamp on odi grips, and also has cascade oem loaction billet light mounts for trail techs or etc..(these aren't pictured), jds under tank relocate bracket with a kompulsive koncepts harness, all tm design rollers guides and case saver, probably more but on to the motor now. Perfect and very clean cases with all internal and external fasteners new oem, 4mil hr crank with max load bearing and extra true and weld, cam atv pro mod trans with ez spring and bearing detent roller, all shift parts are new before having the pro mod done, new oem inner clutch hub and pressure plate, chariot pancake bearing, Mattoon billet basket with driveline clutches, all new oem water pump parts in a new oem clutch cover, has all new plastic covers including the stator cover with stainless bolts, cylinders are 64.5 bore and an aggressive trail port by surfjag( justin gwin), pro design head with 24 cc pump gas domes making 155 psi at 1100asl, new pwk 28 carbs with uni pods, all perfect oem electrical components, Mattoon billet timing plate, new pro circuit pipes. Other setups justin has done with pretty much same mods have dyno at 68hp. The short list of things the bike lacks in being completely finished is a rear grab bar, rear skid, and headlights of your choice. would be hard to find a part on this bike that isn't new or reconditioned to new or better. Bought a rzr and just want to make some mods on it so selling the banshee $6000 obo any questions just ask I built/installed every part on this bike to my very picky standards so there is nothing I won't know about it. Located in the very southeastern tip of Kentucky town called Middlesboro, zip 40965
