hinson quick clutch
I bought a banshee that has a hinson quick clutch. I bought a new cable because it seemed like it was stretched. I adjusted the clutch lever and it doesn't move much and has a bit of free play. I can get it to engage with no issues when I pry on it from the shaft. I was wondering if maybe there is an adjustment on the clutch itself or if there shorter cable I would have to buy?
There is an adjuster behind the pressure plate. Set it so that the arrows on the top half of the engine case and tip of the clutch actuator arm are lined up. With 8 plate clutches (you very well could have) they won't line up, so relatively close is fine.
