sheerider1026 Posted October 9, 2015 Report Share Posted October 9, 2015 I run a 5ah on my bike. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted October 9, 2015 Author Report Share Posted October 9, 2015 Which battery are you using and what are you powering? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted October 9, 2015 Report Share Posted October 9, 2015 eBay special. About 45w of LED lights. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted October 10, 2015 Author Report Share Posted October 10, 2015 I'm running stock for now I'll see what all I can find... I'm kind of limited on what I can get due to size Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted October 10, 2015 Report Share Posted October 10, 2015 Even if I had 125w of light, I'd still be using this 5ah battery. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted October 10, 2015 Report Share Posted October 10, 2015 The battery size just determines how long you can run the lights with the motor off. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted October 14, 2015 Author Report Share Posted October 14, 2015 Chrome battery just sent me a brand new battery, I only had to pay 8 dollar shipping! I will definitely continue to do business with them for their awesome customer service (I was outside of any warranty). Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
blowit Posted October 15, 2015 Report Share Posted October 15, 2015 So did the batt fix your issues? 12.5V is NOT full charge on a 12V battery. 12.7V is standard but with surface charge (just after charging), they are typically over 13V. A rectifier issue can certainly have a draw as the diode pack can leak to ground. That is easily found with a meter though and there are usually other symptoms. Make sure your charging system is getting that battery to full charge. I commonly charge a battery, then let it sit over night unplugged and see if it holds voltage. Bad batteries have either sulfated plates (reduced amps) or shorted plates (voltage leaks down). Just curious. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted October 15, 2015 Report Share Posted October 15, 2015 I suggested hooking a load ( some sort of 12v light) directly to the battery with the engine off and rectifier disconnected. This should rule out everything except the battery. See what the voltage drops down to, and or to see if it evens powers the light. Quote Link to comment Share on other sites More sharing options...
willaduncan Posted October 16, 2015 Author Report Share Posted October 16, 2015 I haven't received the new battery yet... I know the stator is good and I know the harness is good they are both brand new. The rectifier is a brand new trail tech as well Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
willaduncan Posted October 16, 2015 Author Report Share Posted October 16, 2015 Everything is literally brand new... When the battery was first hooked up it powered it all just fine then after sitting a few months now it doesn't do shit Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gst_r Posted October 16, 2015 Report Share Posted October 16, 2015 are you using your stock stator with floated ground? Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted October 16, 2015 Report Share Posted October 16, 2015 Bad battery. I had one do the exact same thing Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted October 16, 2015 Report Share Posted October 16, 2015 He has one of my stators Quote Link to comment Share on other sites More sharing options...
gst_r Posted October 16, 2015 Report Share Posted October 16, 2015 @sheerider1026 You mod stock stators? Quote Link to comment Share on other sites More sharing options...
