Abe Posted October 1, 2015 Report Share Posted October 1, 2015 Need some advice on a small possible rc type battery pack that would be sufficient to keep my lights from flickering at idle. Total of 20 watt draw for both headlights plus whatever a tail light will be. I am running a rectifier type converter that doesn't require floating the ground. Also i have not actually tried running them without a battery. So if you have experienced no flicker with this small of draw lmk as I will ditch the battery idea. Quote Link to comment Share on other sites More sharing options...
Abe Posted October 1, 2015 Author Report Share Posted October 1, 2015 Yeah watts lol fixed it Quote Link to comment Share on other sites More sharing options...
Abe Posted October 1, 2015 Author Report Share Posted October 1, 2015 K thanks for the advise Quote Link to comment Share on other sites More sharing options...
gusto Posted October 1, 2015 Report Share Posted October 1, 2015 what about the rectifier set up ? Quote Link to comment Share on other sites More sharing options...
gst_r Posted October 1, 2015 Report Share Posted October 1, 2015 (edited) I saw one time a box that converts AC to DC (on ebay) but they only allows you to use 6w, something like that; are you using the same box? Edited October 1, 2015 by gst_r Quote Link to comment Share on other sites More sharing options...
90Bansheedude Posted October 1, 2015 Report Share Posted October 1, 2015 (edited) Some rectifier regulators or bridge rectifiers need a battery to work right. I tried a simple bridge rectifier without and burned up a set of lights. Trail techs also says must have one. I used a Tenergy 2000mah battery http://www.ebay.com/itm/Tenergy-12V-2000mAh-NiMH-Battery-Pack-w-Bare-Leads-/390335352447?hash=item5ae1ccce7f It fits in the tool tray very well. I bought 2 but they only shipped one at first, and the one was sufficient, but planned on fitting the 2 in together in parallel for more capacity (4000mah) You can fit 2 of those in the tool tray and with a small piece of velcro, foam and a zip tie, its not going nowhere. I will be getting my shee out possibly this weekend to get it ready for a ride next weekend and if i do and remember, i can take a picture if desired. I like the battery, because then if the quad dies, you still can have the lights for awhile to either see whats going on, or signal for help. Or if you need it to see to fix something on a buddies quad or for loading, etc, you dont have to let it sit there idling. I would highly recommend going for the $60 Trail Tech one, it works great, is adjustable and has a time delay off feature that is just, well, kinda cool. Edited October 1, 2015 by 90Bansheedude Quote Link to comment Share on other sites More sharing options...
Abe Posted October 1, 2015 Author Report Share Posted October 1, 2015 I plan on mounting up front somewhere is why I wanted it small, I only have one wire going to the rear for my tail light and it is inside the frame rail. Would like to keep the wiring to a minimum for a cleaner look. Quote Link to comment Share on other sites More sharing options...
Abe Posted October 1, 2015 Author Report Share Posted October 1, 2015 Also the box is from ebay but didn't list any maximum watts to be drawn.http://m.ebay.com/itm/Yamaha-Universal-Rectifier-Converts-12V-AC-to-12V-DC-Voltage-/171266352569?nav=SEARCH Quote Link to comment Share on other sites More sharing options...
90Bansheedude Posted October 1, 2015 Report Share Posted October 1, 2015 http://www.ebay.com/itm/Trail-Tech-Full-Wave-DC-Switching-Regulator-Rectifier-w-Auto-Shut-Off-7004-RR150-/171840281574?hash=item28027a9be6&vxp=mtr Trail tech one is only $54, not much more and can handle 150 watts. I would recommend it. Quote Link to comment Share on other sites More sharing options...
90Bansheedude Posted October 1, 2015 Report Share Posted October 1, 2015 You don't have to float the ground on the trail Tech one either. I talked to the tech guy just to make sure and did not float it on mine and it works wonderful actually. I would actually be very curious what he actually has inside of that box if it's just a standard $5 bridge rectifier or if there's a lot more. Does it come apart easy to take a peak? Sent from my Samsung S3 on Tapatalk Quote Link to comment Share on other sites More sharing options...
90Bansheedude Posted October 1, 2015 Report Share Posted October 1, 2015 No problem do it how you like. Would anyone be game to peak inside that box and see what's inside? Sent from my Samsung S3 on Tapatalk Quote Link to comment Share on other sites More sharing options...
Abe Posted October 1, 2015 Author Report Share Posted October 1, 2015 Already got it steven, and I'm sure your light bar is drawing alot more power than my 2 trail tech equinox lights. They actually have a lo, med, and hi at 3, 6, and 10 watts useage per light. Quote Link to comment Share on other sites More sharing options...
gst_r Posted October 2, 2015 Report Share Posted October 2, 2015 Already confused, I have been thinking on doing the dc conversion (floating ground, battery, etc), I discarded the box from ebay because supposed will only allow low wattage use, but well seems that it works correctly Quote Link to comment Share on other sites More sharing options...
90Bansheedude Posted October 2, 2015 Report Share Posted October 2, 2015 Probably depends on how hot it gets because inside the plastic box it can't really dissipate heat much. All you can do is try it and see and if it doesn't work go to the trail Tech one you can choose to float the ground or not either way Sent from my Samsung S3 on Tapatalk Quote Link to comment Share on other sites More sharing options...
90Bansheedude Posted October 2, 2015 Report Share Posted October 2, 2015 I'm still curious on what exactly it has inside of it if he gets to take it apart to find out and maybe it'll have some specs on the parts inside or we can look them up from part numbers or stress test it adding wattage until it blows if someone wants to find out for everybody else. Or did anybody actually asked the seller to see if he knows how many watts Sent from my Samsung S3 on Tapatalk Quote Link to comment Share on other sites More sharing options...
