trickedcarbine Posted October 7, 2015 Report Share Posted October 7, 2015 Haha! Quote Link to comment Share on other sites More sharing options...
Abe Posted October 8, 2015 Report Share Posted October 8, 2015 Just a tip, the full bearing clip doesn't always fit the cases. I have also heard some older cases don't have the upper half grooves at all. In my case I had the grooves but there was still too large of an od on the clip for my cases to fully seat. Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted October 8, 2015 Report Share Posted October 8, 2015 I've ru tz on various engines and havnt had on failure , for this particular build maxloads are the way to go Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 8, 2015 Report Share Posted October 8, 2015 Just a tip, the full bearing clip doesn't always fit the cases. I have also heard some older cases don't have the upper half grooves at all. In my case I had the grooves but there was still too large of an od on the clip for my cases to fully seat.Wrong clip. Can even double up the OEM ones. Quote Link to comment Share on other sites More sharing options...
registered user Posted October 8, 2015 Report Share Posted October 8, 2015 the riveted brass cage style that were commonly used by quit a few folks had some failures. crankworks wont even install that kind anymore. seen em fail on single cylinders also dont quote me but i think some of the full circle clips might be slightly bigger diam that 2 oem clips. if the cases wont cinch down this is likely why. cut a few more thousands out of the groove and you be aight or grind the outside of the clip Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted October 9, 2015 Report Share Posted October 9, 2015 Some of the tz failures I've seen the outer race split rite at the clip groove, I use oem half clip for the past 5 or so yes with no problems my guess is just a touch to much pressure on outer race . They'll live for a lil them boom Quote Link to comment Share on other sites More sharing options...
Big Mike NY Posted October 9, 2015 Report Share Posted October 9, 2015 I've ru tz on various engines and havnt had on failure , for this particular build maxloads are the way to go My brother came by my house tonight, took the bike for a rip! He's amazed at the power difference and just how hard the powerband hits! Your porting and the Shearers are a match made in heaven!! The bike also shifts so much better it shifts better than when it was brand new!!! Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted October 9, 2015 Report Share Posted October 9, 2015 I took the chuck wagon out of it lol. Quote Link to comment Share on other sites More sharing options...
special06shee Posted October 9, 2015 Report Share Posted October 9, 2015 I took the chuck wagon out of it lol.Lms had a cr500 with chuck wagon engraved in the cylinder. Haha. Thing actually ran very well compared to my stock 500. Quote Link to comment Share on other sites More sharing options...
Lowroll Posted October 9, 2015 Author Report Share Posted October 9, 2015 Alright, got my refund from HJR, shipped his crank back this morning. Im going to get the new crank on the way so I can build my engine next weekend. 4mil hot rods crank 2 max load bearings Fresh copper washers for the head and an extra set of dome of rings just in case. My crank seals were brand new a month ago and they look fine, I have new gaskets. Anything else? And does anyone know if fast will put the new bearings on the crank for me? Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
possum Posted October 9, 2015 Report Share Posted October 9, 2015 Crank seals are fine. I like to put them back in the same way tho. They will usually have a lil mark on the rubber where the case halves meet. Rotate it back to that spot. Thats what I do never had a problem. Quote Link to comment Share on other sites More sharing options...
Lowroll Posted October 9, 2015 Author Report Share Posted October 9, 2015 I did notice that little mark you're talking about, I'll watch that when it goes back together. I'm going to use waterproof grease this time too as recommended by sleeper06. He said it'll hold up the best long term. Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted October 9, 2015 Report Share Posted October 9, 2015 Waterproof grease where? Quote Link to comment Share on other sites More sharing options...
Lowroll Posted October 9, 2015 Author Report Share Posted October 9, 2015 In the grease grooves of the crank seals Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted October 9, 2015 Report Share Posted October 9, 2015 At one time chuck was good builder, unfortunately he knows squat about banshees . He does build n port quite a few . He's the reason I started porting years ago . His magical jet size is 300 main every bike gets it rite wrong or indifferent. I have so many stories it's unreal he's the only one that gets away with charging to build a bike and let's it leave fucked up but swears it's the bomb 1 Quote Link to comment Share on other sites More sharing options...
