Lowroll Posted September 30, 2015 Author Report Share Posted September 30, 2015 Sounds good. I really appreciate all the input. As soon as I get home I'll pull the jugs and try to get some answers tonight. Even if I'm unable to call Kevin or cam, I'll atleast be able to post here and see what the concensus is Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 30, 2015 Report Share Posted September 30, 2015 tricked I said before its not going to tell you anything. what if he changed the exhaust port floor or what if he didn't.. you don't knowI'm aware you said that.... But I posted exactley why I said to check it. If the piston is already protruding in to the exhaust, then it wouldn't be a good idea to go messing with the base gasket and lowering the cylinder. But if the piston is below the exhaust, and you're not disturbing the piston/transfers much then you know you got some room to work with thinner base gaskets. You're correct about not knowing what he did with the exhaust, but I've seen a dune port and a couple MX/hardcore ports from him and they leveled out. So to me this set up is quirky from the second he said the piston is lower, as I've seen several of Kevin's set ups and they sat flush. Quote Link to comment Share on other sites More sharing options...
Lowroll Posted September 30, 2015 Author Report Share Posted September 30, 2015 Tricked, I will get that number for you tonight. I also feel as though I might be able to go to a thinner base seeing as my piston sits lower than the port at bdc. Aside from that measurement, and the base, what else should I measure Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 30, 2015 Report Share Posted September 30, 2015 Before ordering any domes if you have to.... You will wanna mock the cylinders up on whichever base gasket you decide to run. That way the cylinders are situated where they need to be so you can get an accurate deck height. (Distance between piston edge and cylinder deck) It's totally possible you can run a different base gasket and continue on with those domes(doubtful IMO), but I think everyone agrees that the gasket is the first thing that needs to be addressed. If it's already to thin to lower it, then you have a lot more work to do. 2 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 30, 2015 Report Share Posted September 30, 2015 Tricked, I will get that number for you tonight. I also feel as though I might be able to go to a thinner base seeing as my piston sits lower than the port at bdc. Aside from that measurement, and the base, what else should I measure Sent from my SM-N910V using Tapatalk Current deck height Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 30, 2015 Report Share Posted September 30, 2015 MY CUSTOMERS WIN AT ALL THE TRACKS.Honestly, IMO (here comes the flame) the last HJR motor I saw that ran the way it should was Dajoger's. It was piloted to victory many years ago. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 30, 2015 Report Share Posted September 30, 2015 Bro you live 2.5 away from Justin. Load up the bike, load up the cooler, and pay someone that knows what there doing and can do it right in front of you. If anything ever happens you can go back. Hjr is literally on the other side of the country Quote Link to comment Share on other sites More sharing options...
Lowroll Posted September 30, 2015 Author Report Share Posted September 30, 2015 Bro you live 2.5 away from Justin. Load up the bike, load up the cooler, and pay someone that knows what there doing and can do it right in front of you. If anything ever happens you can go back. Hjr is literally on the other side of the countryI couldn't go see him for a few weeks. I'm busy the next 2 weekends and Saturday the 17th Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 30, 2015 Report Share Posted September 30, 2015 I couldn't go see him for a few weeks. I'm busy the next 2 weekends and Saturday the 17th Sent from my SM-N910V using Tapatalk I'm sure you'd have to make some sort of appointment. I'd shoot him a message. I found it easier to have some one work on my bike. Saves me a lot of headache Quote Link to comment Share on other sites More sharing options...
Lowroll Posted September 30, 2015 Author Report Share Posted September 30, 2015 No doubt about that. I'll shoot him a text and see when he could help me out. I could possibly go this Sunday if he was free. My weekends are pretty loaded Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted September 30, 2015 Report Share Posted September 30, 2015 Yup I think this little hurricane will cause the race to be cancelled so I will be home tinkering Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted September 30, 2015 Report Share Posted September 30, 2015 Surf you have any bottom ends over there if I sent you a cpl set of cylinders to dyno or send the completed engine I've got a stock cyl 4 mil that dynoed 105 hp not to far from me but I don't trust the operator he's a utv guy and a lol special Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted September 30, 2015 Report Share Posted September 30, 2015 There talking hurricane will hit u direct. If you ever want to sell that dyno let me know !!!!!!!! Quote Link to comment Share on other sites More sharing options...
Lowroll Posted October 1, 2015 Author Report Share Posted October 1, 2015 Okay, I have some numbers. My bore is 64.3 My pistons sit .065 above the deck My pistons drop roughly .005 below the exhaust port (it was hard to measure with accuracy) And depending on where I measure the base gasket it shows anywhere between .019 & .029 Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lowroll Posted October 1, 2015 Author Report Share Posted October 1, 2015 And we found the issue. We measured the stroke of the engine, 57.81mm, so it's only a 3.81mm stroker which is the .019 I'm currently off. Surf jag told me to check that out and sure enough. So.... Until I'm ready to buy a HR crank and change cylinders I'm going to roll with what I have and have new domes cut to work with what I currently have Sent from my SM-N910V using Tapatalk Quote Link to comment Share on other sites More sharing options...
