Ok guys, I have a question about doing a plug chop. I know you need to do a 6th gear pull wot then cut the engine and cost to a stop. Now, the question is, do I need to hold it wide open through all the gears to 6th gear or can I take it a little easy up to 6th then pin it? The reason I'm asking is because the thing doesn't want to shift well under pull power. I know I need to get the trans cut but I want to wait til the winter to pull the motor apart again. I just want to check my jetting to get some riding in before the winter
Sent from my VS980 4G using Tapatalk
Yes that's fine bring it through the gears easy I don't bounce the thing off the limiter either but end it wide open leaving throttle open through shutdown and coast
You mean it's not a good idea to totally cut fuel at 9,000 RPM's?
I tell people to do it that way and just get told that the fuel will wash the color, but IMO good color won't wash.
