Yami-Rider Posted September 25, 2015 Report Share Posted September 25, 2015 So, a guy brought me a 05 banshee basket case. I have it put back together, but I'm not sure on what parts I'm missing for the stroker kit. Motor has a wiseco +4mm stroker crank, stock unported cylinders, Cool head with 18cc domes, customer just wants it to run again. It had Vito Super Sport pistons in it. They had been kicked around and the rings were rusty, so i didn't want to put that back in. Vito's are on back order for 2-3 months. I noticed they have the same wrist pin to dome height as Wiseco Pro-lites. So i orders pro-lites and bored to fit. Wasn't sure how that was going to work being its a stroker motor...well it doesn't, the top ring sticks out the top of the cylinder. So, am i missing a really thick spacer plate? Should i have ordered the Wiseco stroker pistons? How did these vito's work, must of had a spacer plate..correct? What's my cheapest option? just trying to make it run again. Any help will be really appreciated. I know a bit about 2-stroke pwc motors, and 4-stroke quads, but this is the first banshee I have mess with. Quote Link to comment Share on other sites More sharing options...
Yami-Rider Posted September 25, 2015 Author Report Share Posted September 25, 2015 You can see the top of the wiseco and vito's are the same height Piston sticks out the top of the cylinder Quote Link to comment Share on other sites More sharing options...
Yami-Rider Posted September 25, 2015 Author Report Share Posted September 25, 2015 (edited) Im thinkin i need to order the wiseco pistons for +5mm long rod application(795M06450) and possible a spacer plate kit, or order the correct domes for this cool head? Edited September 25, 2015 by Yami-Rider Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 25, 2015 Report Share Posted September 25, 2015 No spacer plate! Get the 795's if you have a long rod stroker crank. The piston crown will still be above deck a little, but you cut the domes to compensate. You will need to have porting touched up though. OR.... CALL DRIVELINE.(Lane is the son of Vito's founder) They got a new piston that makes it all work pretty damn well with out all the extra work. Quote Link to comment Share on other sites More sharing options...
Yami-Rider Posted September 25, 2015 Author Report Share Posted September 25, 2015 (edited) Thanks for the info. I went ahead and ordered 795's, so i can have them monday. Do you have to special order the cool head stroker domes from pro design? Not seeing stroker domes in the book by that company. What kind of port work needs to be done? any info on that? Will it run like crap if i just put it together without the port work? Edited September 25, 2015 by Yami-Rider Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 25, 2015 Report Share Posted September 25, 2015 This is for a customer?like there paying you to do this? 1 Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted September 25, 2015 Report Share Posted September 25, 2015 FFS Quote Link to comment Share on other sites More sharing options...
Yami-Rider Posted September 25, 2015 Author Report Share Posted September 25, 2015 (edited) This is for a customer?like there paying you to do this? Yap. Would be pretty straight forward minus the strokers issues. I have built plenty of motors in the past. Just never mess with banshees, but they are all basically the same. Looks like his son, put the stroker crank in but didn't go any further. So that would explain why the top end isn't right. Looks like ill just cut these domes to the right squish. Will it run at least as good as stock if you don't port the cylinders? He just wants it to run again. FFS Maybe this has been covered many times? A link would be a lot more helpful... Edited September 25, 2015 by Yami-Rider Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 25, 2015 Report Share Posted September 25, 2015 My condolences to your customer. Quote Link to comment Share on other sites More sharing options...
bigweav81 Posted September 25, 2015 Report Share Posted September 25, 2015 Oh boy. sent from yo mammy house. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted September 25, 2015 Report Share Posted September 25, 2015 Lmao Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted September 26, 2015 Report Share Posted September 26, 2015 Call fast racing order 24 cc stroker domes and an oring kit , do yourself a big favor and pressure test that motor before you put it in the frame an air leak will destroy all your new parts and also serves as a check on seals if the owner even replaced them with new crank Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted September 26, 2015 Report Share Posted September 26, 2015 Call Lane or Bill at Driveline they will help you iron out your problems. Sent by me FFS from Tapacrap 1 Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted September 26, 2015 Report Share Posted September 26, 2015 Lane is not related to Vito. But yes, we could set you up with the correct pistons and corresponding domes. Your piston is traveling 7mm higher with a long rod 4m stroker. The 5mm longer rod is made up for with the 795 pistons leaving you with 2mm to make up with either base gasket and or cutting domes. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 26, 2015 Report Share Posted September 26, 2015 Lane is not related to Vito. But yes, we could set you up with the correct pistons and corresponding domes. Your piston is traveling 7mm higher with a long rod 4m stroker. The 5mm longer rod is made up for with the 795 pistons leaving you with 2mm to make up with either base gasket and or cutting domes.No shit? I was always under the impression they were family. That's a trip. Quote Link to comment Share on other sites More sharing options...
