Temp Gauge
SoonerFanAZ
You can get the Mr. Gasket ones for import in lower pressure. They don't last. Mine didn't even make it past a season of ice racing on flat ground. Maybe 6/7 rides. And it always read wrong.
JMO, the barb of a hose should be equal to the inner hose diameter or slightly(just a cunt hair) larger then the I.D. Of the hose. If you got a chunk of metal that fits right and holds an accurate gauge, run it.
I wouldn't.
Aren't those high pressure caps? So it can get up to super hot temps?
I'd want my cap to open and start puking.
Good question, I bought model #2473s, 16 psi. Clymers says stock cap pressure is 13.5 - 17.8
