sheerider11 Posted September 26, 2015 Report Share Posted September 26, 2015 Right out of the head is what you want 1 Quote Link to comment Share on other sites More sharing options...
monster Posted September 26, 2015 Report Share Posted September 26, 2015 (edited) Best place is in upper hose from head! Coolant flows from lower radiator into water pump to cylinders then out of the hot head to top of radiator cools in radiator back to pump! Edited September 26, 2015 by monster 1 Quote Link to comment Share on other sites More sharing options...
thomas h. Posted September 26, 2015 Report Share Posted September 26, 2015 TTO here as well, used a few of them very handy to have Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted October 12, 2015 Report Share Posted October 12, 2015 I keep a super cooler in the parts box. It would come in handy if you had to splice a hose back together. As for cutting a good hose to put one in, I'd pass. Quote Link to comment Share on other sites More sharing options...
JTmachining Posted October 12, 2015 Report Share Posted October 12, 2015 I use/used ESR ones and have no had problems 1 Quote Link to comment Share on other sites More sharing options...
do-work-son Posted October 12, 2015 Report Share Posted October 12, 2015 This. I'm running one on my bike but I bought the 19mm, this link is for a 22 mm. Only downside is that you can't reset the "max temp". It shows the current temp and occasionally flashes max temp which is just the hottest your bike has ever gotten up to. It should reset every time you bike heats up again. Should be the hottest it got on that ride. Or ya can unplug it then plug it back in. I got the 19mm and thought it fit was small. Picked up the 22mm and it was tight but felt it filled the hose better. 1 Quote Link to comment Share on other sites More sharing options...
Rage_kage Posted October 12, 2015 Report Share Posted October 12, 2015 Excuse the dirty rad hoses but that's how my trail tech is setup, its easy and convenient. 1 Quote Link to comment Share on other sites More sharing options...
lowidenfast Posted October 12, 2015 Report Share Posted October 12, 2015 It should reset every time you bike heats up again. Should be the hottest it got on that ride. Or ya can unplug it then plug it back in. I got the 19mm and thought it fit was small. Picked up the 22mm and it was tight but felt it filled the hose better. I didn't realize that it was supposed to do that. I've only ridden a few times with it though. I'll py attention next time and, if it doesn't reset, I'll just unplug it like you said. Thanks Quote Link to comment Share on other sites More sharing options...
ScEaMin BaNsheE 305 Posted October 12, 2015 Report Share Posted October 12, 2015 (edited) that handle bar pad cut out for temp gauge is good idea, shit now im debating whether to get the 19 or 22 mm tto Edited October 12, 2015 by ScEaMin BaNsheE 305 Quote Link to comment Share on other sites More sharing options...
do-work-son Posted October 12, 2015 Report Share Posted October 12, 2015 I have one of each on different bikes. They both work. Both 22mm i got where metal and blue and the 19mm one I got was black plastic. Don't think I could pick a housing color but could get the display part in different colors. Rage-kage looks to be the 22mm Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted October 12, 2015 Report Share Posted October 12, 2015 The high temp resets when temp drops below 125º.The old ones had a plastic temp tube... they were shitty and returnable. Newer style is aluminum.I went with the 22mm as well and have been happy with mine over the 3 years I've had it. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted October 12, 2015 Report Share Posted October 12, 2015 http://redlineracing.biz/shop/line-temperature-gauge/ Quote Link to comment Share on other sites More sharing options...
registered user Posted October 13, 2015 Report Share Posted October 13, 2015 Those redline ones are the same size as esr. Loose as fuck in the banshee size hose. Have to tightenen the piss out of the clamp Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted October 13, 2015 Report Share Posted October 13, 2015 They are a little loose. That said, we've got them on two bikes with no issues. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted October 14, 2015 Report Share Posted October 14, 2015 Those redline ones are the same size as esr. Loose as fuck in the banshee size hose. Have to tightenen the piss out of the clampAgain your comments hold no merrit. These things are fucking everywhere, working just fine, with no issues. Just like 4mil hotrod cranks. You continue to pick apart shit that has proven itself 1000s of times over. Get a clue moron. Here's a real question. Do you pull Johns dick out of your mouth while you type this shit, or do you continue to gargle the entire time? Quote Link to comment Share on other sites More sharing options...
