Checking Compression
cmyyard19
I use a KEM professional series compression guage. I can get it in there, with the included adapter with the tank still on. Now, if you believe you have an air leak, than you need to do a leakdown test. This requires a vacuum pump, and some other accessories. Search the forum, and you will find a thread or two on this that explains this in detail.... And your compression guage should hold the highest reading. If it doesn't, it is a POS and you need to get a good one...
Some compression guaged have a thing that looks like a tire vavle needle that goes inside the tire vavle steem. They do go bad and even stick giving you a lower reading. If you have the sunpro version, they will usually send you a new valve to thread in there for free if you just call them. It's leaking or the 30psi would stay on there.
