My shee is lagging or acting sluggish before I hit the band. Feels like it's loading up with fuel or something. Mods are-
F.A.S.T. 421 4mill long rod serval with clean up port
F.A.S.T. head 26cc domes .048 squish
+4 timing
V4reeds
Single intakes no crossover
CPIssb
35pwkS synced with tool 52 pilot 1.5 out, CEL needle 4th clip, and 160 mains
300ft 80deg
What do you guys think...
It's not coming on to the band smooth. It's loading up or something. Just wanted suggestions on what you guys thought. I'm thinking the needle is to rich. Was going to drop it to the middle clip. Maybe even drop the pilot. The bottom end seems weak for this setup. Maybe raise my compression will help. Im prettysure it's at 135+-. Going to test it tonight. You think that will help also? I'm not sure
I wouldn't say it's surging. Kind like a rich studder then hits. Struggles to get on the pipe. I'm dropping my cel needle to the middle clip. Putting a 48 pilot in. My compression is 148 right 150psi left.
I'm at the middle clip now and I put the 48 pilots in at a 1.5 out. It starts without the choke. As far as I know, that means I should put in 45 pilots and my pilots should be perfect????. 300ft
Yea I plug chopped my bike with 9es plugs cause Jeff told me to but everyone says it's too cold for my set up and my plug chop left only half a dark ring around it so someone said the plug is too cold anyway. I'm going back to Br8es and going to redo my chop
  • Like 1
