nice 4mm for sale. $2800
DEM3500
ive had this posted in the past but a lot has changed so im starting over.....
its had a handful of rides on it since i had if for sale the last time. but still not many at all. its been sitting in my barn since last summer and i just brought it out once last month. the most recent ride i let a buddy ride it and like an idiot he took it through deep water (no air box) and messed up something. it backfires so bad out of the right cylinder it blows the pipe off the head tube. i havent opened it up yet nore do i really want too lol but i will if i need to. so lets just assume it needs a whole top end.
located in Burton MI
$2800
i tore this thing down last summer to the frame and powder coated everything! frame, arms, front bumper, rear grab bar, nerf bars and swinger are prismatic powders splatter black
http://www.prismatic...splatter-black/
the hubs, spindles, brake hub, and sprocket hubs are prismatic powders ink black
http://www.prismatic...106S/ink-black/
the port work is 1 out of 2 banshees that exist that have this engine setup. the only other bike thats setup like this was dynode at 70hp. i can say this with confidence because the guy that did the work is one of my best friends. i never dynoed it cause i really dont care about numbers. i just like to ride fast lol. if you are seriously interested in this i will give you the builders info.
4mm stroker with matching port work.
its runs on 110 octane and has only ever had amsoil dominator run through it.
if i remember right its on its second or third bore.
the head was shaved down and re domed to match the 4mm crank. basically it all looks like a stock banshee engine. its a total sleeper.....until you start it up!
+2 +1 ASR a arms with newer teflon lined heims
+4 roundhouse swinger with new pivot bearings (i think LSR)
billet impeller with inline coolant cooler with temp gauge
+1 antivibe steering stem with NEW bushings and bolts
pro taper bars
ASV C6 brake and clutch levers
newer brake pads front and rear
Nology profire coil with acell 8.8mm wires
http://www.farmandsa...l.asp?partid=46
GB racing CDI relocation bracket
http://www.banshee-p...cket-gb-racing/
tusk adjustable width rear axle
https://www.rockymou...dth-Racing-Axle
FMF SST pipes with NEW o-rings
brand NEW UNI pod filters
34mm mikuni round slide carbs
TORS eliminitated
teather kill switch
shift drum has been modified with a roller bearing
shift shaft has been modified
scratches on the plastic but no cracks
gripper seat cover with one small 1/2'' tear.
axis single rate rear shock with remote rezzie. rebound and compression adjustable
works tripple rate front with remote rezzie
im sure theres more that im forgetting. theres nothing much left thats still stock. this thing rips. theres no doubt about it. i hate to let it go but i just dont ride it anymore.
IMG_20140913_190624483_HDR_zps8c49d120.j
IMG_20140913_190542712_HDR_zpse04e5ecc.j
IMG_20140830_134046170_HDR_zps90901f09.j
IMG_20140830_205052826_HDR_zps75c7341c.j
