Banshee issues....I'm new
Bigtex45
Sheerider is correct. Do some searching on how to do a leak down test and compression check. A leak down tester will cost you about $25 dollars in parts and get yourself a good compression checker ( snap on, Mac, craftsman).
91 octane is way low for that motor if you are running 19cc domes. You will probably be closer to 110 octane. If you don't want to run race gas, change out your domes to 21cc domes.
Are you running any advanced timing? That will play a factor in your octane choice also.
Sent from my VS980 4G using Tapatalk
Don't do that. It will run like crap. First decide what fuel you want to run, then build from there. Once again, with 19cc domes and any amount of advanced timing, you are looking at race gas. If you want to run 91 octane, I would go to 22cc domes and 0 to +2 timing.
So blow it the fuck up I don't care. You ask for help and I give it to you.
Yes you do need these tools. A compression tester Wil tell you you have 200 psi of compression. At that point it's safe to say you need race fuel.
But putting your dick beater over the hole will do.
A leak down tester will show if you have an air leak causing a lean condition and burn up your motor.
But just assume it's fine. There not important.
You clearly have it figured out and you just want someone to tell you you're doing great.
No one gives a fuck youre in high school. We've all been there and we all work. Get the fuck over yourself.
  • Like 1
And let's say it didn't hold air for 6 mins what do I do if it doesn't??
Find the leak and fix it. If you're running 5 degrees on timing and 19cc domes on pump fuel that is most likely your problem. It's always safe to leak test the motor too just to be sure. Use it once? I check mine a couple times a year. If you can't afford these things, then you have no business owning a banshee.
